05-28-2019 06:07 AM - edited 02-21-2020 09:10 AM
I configured route-map on FMC, then I configured a text object as a next hop for the PBR.
I used this object in the Flex configuration, for the PBR, and everything was fine, after deployment I checked the configuration on the FTD, but something weird happens, the configuration has been applied as below
route-map Test_PBR permit 10
match ip address PBR_ACL
set ip next-hop peer-address
so I checked the deployment history, and error appears in the deploy transcriot
ERROR: Peer-address and specific IP address can not be mixed.
any help.
Thank you all in advanced.
05-28-2019 07:00 AM
check this link similar issue.
https://community.cisco.com/t5/firepower/pbr-on-ftd/td-p/3327116
https://www.youtube.com/watch?v=lakHhw9CR5Y
05-28-2019 07:39 AM
Dear Sheraz.Salim,
This is another problem and I already checked the attached video, all configuration is done like the video but the output on the device is different.
Thank you in all cases.
