Reset ASA Firepower on ASA 5506-X
fs0000001111
I want reset to Factory Default on Cisco ASA 5506-X.
I try with ASDM, and console mode, but the ASA Firepower are always configure ( Licence Agree, Enable, and IP Configure)
How reset the firepower to factory Default?
Marvin Rhoads
What's your goal in doing so?
If you want to really take it back to zero configuration, you can always uninstall the FirePOWER module and re-image it from scratch. The ASA cli command to do that is:
sw-module module sfr uninstall
You would then have to reload both boot and system images to get it running again.
I made a mistake in my testing, and arrives change this setting.
I would like to reset the ASA Firepower to start from scratch.
I'm going to try.
Thanks.
OK. If you do the uninstall, you will need to first make sure you have on hand the boot image (.img file) and install package (.pkg) files to re-install. Assuming you have entitlement to download, those can be found here:
https://software.cisco.com/download/release.html?mdfid=286283326&flowid=77251&softwareid=286277393&release=6.0.1.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Complete installation instructions can be found here:
http://www.cisco.com/c/en/us/support/docs/security/asa-firepower-services/118644-configure-firepower-00.html#anc7
Please mark your question as answered if it has been.
