Security intelligence warning
draganzec
after upgrade of FMC and firepower versions from 6.2.3.14 to v6.3.0 there is a health warning regarding FMC saying Security intelligence - module1 and module2 is out of date for the IP and URL list.
I checked this troubleshoot guide https://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/117997-technote-firesight-00.html and every step is OK.
I also checked locations on modules:
Network– /var/sf/iprep_download
DNS– /var/sf/sidns_download
URL– /var/sf/siurl_download
and found files with date later then warning itself. So I guess that sync between FMC and modules exist.
Can you please give some suggestion what to try next?
Thank you.
Br,
Dragan
Marvin Rhoads
This is a defect (bug).
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvm60548
It's fixed in 6.3.0.2
https://www.cisco.com/c/en/us/td/docs/security/firepower/630/630x/relnotes/firepower-release-notes-630x/resolved-issues.html
If you go to 6.4 (or later) the issue should not be present there as well.
