11-22-2017
02:28 AM
- last edited on
02-21-2020
11:34 PM
by
cc_security_adm
After I upgraded my FMC to 6.2.0 version, when second user try to login into FMC (WEBUI)
it shows "Existing session detected , You are already logged in as this user.Do you want to proceed and terminate previous session?"
11-22-2017 02:52 AM
11-27-2017 09:24 PM
Hi Mikael,
Yes, I use same username. I used to do it in the version 5.4.X but in 6.2 version I am not able to do simultaneous login. Is there any version dependent limitation ?
11-27-2017 11:43 PM
12-22-2017 10:28 PM
03-23-2018 11:31 PM
Difficulty in having multiple windows open at once was a design choice Cisco made. It was a bad one, and they should undo it, but it's minor and annoying, rather than a serious functional problem.
If you have one window or tab open, at least in Chrome or Firefox, you can right-click on things in that tab to open them in other windows or tabs, and it works just fine. But if any of them times out, logging back into it trashes the whole session, so you can't; you'll have to remember what you were doing and reopen it from a live tab.
I very often have multiple sessions open, especially when I have two screens available, with one of them showing a Summary tab and maybe task status, and another few doing updates or working on policies.
