Cisco Community Designated VIP Class of 2020
454
Beginner
Smart Licenses on Cisco firepower management center
I have to apply Cisco Smart License for FTDs through FMC but my FMC cannot get access to cisco server for registration
How we can make my FMC to get access to internet.
Need your help please !!!!!!!!
1 ACCEPTED SOLUTION
Hall of Fame Guru
Re: Smart Licenses on Cisco firepower management center
Yes. Please see the following section in the configuration guide to setup your DNS server (s) and proxy server:
https://www.cisco.com/c/en/us/td/docs/security/firepower/640/configuration/guide/fpmc-config-guide-v64/system_configuration.html#ID-2241-0000041e
Without that working, the FMC will not be able to register with the Smart Licensing portal. It's also required for it to other important things like download Security Intelligence feeds and other updates.
4 REPLIES 4
Hall of Fame Guru
Are you able to resolve public DNS addresses from your FMC cli?
Are you using a proxy server for Internet access in your environment?
Beginner
Yes I'm using a proxy server for Internet access in the network environment !
Not able to resolve public DNS addresses from FMC !
Is this the issue ?
Hall of Fame Guru
Beginner
Very helpful !
Thank you Marvin Rhoads
Content for Community-Ad
FusionCharts will render here
