Stuck PKCS12 FMC / FTD
Luke Fahey
Hi There
I was installing a certificate for anyconnect VPN and i have managed to import a PKSC12 but forgot to enter the passphrase during installation.
The enrollment failed to deploy and i couldn't remove the certificate because it was in use by anyconnect. I imported another certificate, however i still can't remove the first one. When trying through FMC i get object deletion restricted, Remove from the device.
If i go to the device and try and delete it i get Last global Deployment to the device was unsuccessful. Please try again after the global deployment completes.
The issue is it wont complete because this certificate
FMC >> aaa-server test-radius protocol radius
FMC >> exit
FMC >> ssl trust-point certname
DASA Firepower 2110 >> error :
ERROR: % Invalid input detected at '^' marker.
Config Error -- ssl trust-point certname
Any ideas would be appreciated.
Luke Fahey
Managed to resolve this issue. Although the cert was not tied to any connect, Once i deleted the any connect config it allowed me to remove the cert from the device then fmc.
