05-09-2019 04:25 PM
Hi When submitting for analyze option on a captured file. How do I know where to check the results?
Can I get emailed?
See attachment for eg
Solved! Go to Solution.
05-28-2019 07:37 PM
05-09-2019 07:18 PM
In this menu, you should see all files analyzed:
And when you click on the category you should be able to see if it's been locally analyzed or not and the threat score:
If you do a right click on the file and click on File composition you'll get more information:
Also on clicking on switch workflow at the right of the title captured file summary, you'll get a file analysis status.
If you want to get them by email, you will need to create a report for Captured files and configure the report to be sent by email.
05-27-2019 03:18 AM
So after manually submitting, should I wait 5 minutes and run all those ideas you had? Or wait a day etc?
05-28-2019 07:37 PM
