Beginner
View specific client info FMC
Does anyone know if it is possible to view live data from a specific client IP, or more specifically, the ports the firewall is blocking from that client?
A client has a piece of hardware that’s trying to connect on some obscure port but the installers don’t seem to know what port it needs open and It would be really helpful if I can see which ports are being blocked.
Everyone's tags (3)
1 REPLY 1
Hall of Fame Master
Re: View specific client info FMC
Analysis > Connection Events. Edit the search to specify the source IP of the client and Action is Block.
