08-04-2017 07:48 PM - edited 03-12-2019 06:28 AM
I recently noticed that my Firesight Defense Center has options to use and apply NAT and VPN configurations to my firewalls. This was a bit confusing to me as to my understanding Firesight only touches the Firepower modules that connect to it so I wanted to see if anyone in the community had prior experience with these features.
1: When applying a VPN or NAT configuration to a device through Firesight, are those VPN connections and NAT translations taking place within the Firepower module or is this an area where Firesight's tendrils can reach across into ASA territory and modify its config?
2: What would happen to the original NAT or VPN configuration on the ASA if Firesight applies a configuration to the device? Would it be wiped, or perhaps would only conflicting rules be rewritten
Solved! Go to Solution.
08-07-2017 10:43 PM
NAT and VPN in FMC generally refers to the features when used with FTD devices - i.e., not ASAs with Firepower service modules.
08-07-2017 10:43 PM
