07-12-2012 04:22 AM - edited 03-11-2019 04:30 PM
I have a network with 3 sites that are on different subnets. Each site has an ASA
Right now, I am only able to connect to the ASA that is connected to the subnet I am connected to.
I want to be able to connect to the ASA that are on the remote subnets on the address of the inside interface.
The sites are connected all together by site-to-site VPN.
Is there any way I can achieve that without opening the outside interface directly on the Internet?
Thank you.
Solved! Go to Solution.
07-12-2012 06:01 AM
Yes you can.
On the remote ASA, configure the following:
management-access inside
telnet
Assuming that the inside interface of the ASA is part of the crypto ACL.
07-12-2012 06:01 AM
Yes you can.
telnet
07-12-2012 07:51 AM
Yes you can do that...... You need to allow management access to the inside interface....
Also i suggest you to have ssh access instead of telnet.....
ssh
Also the acls needs to very clear in allowing the access
The below document clears you better if you go through...
To configure the management interface, enter the following command:
