Welcome to Cisco Firewalls Community
221
Access problem from Inside to DMZ and outside to DMZ
So long time lurker, first time poster. These FTD firewalls are making me feel like a greenhorn again. I've slogged through the initial configuration, have interfaces and etherchannels finally working... but cannot for the life of me configure access from our inside networks to our DMZ. I configured NATs in the vein of our configuration on the older ASA5525s without success.
Thoughts? Help?
I'll hang up and listen.  :)
Everyone's tags (4)
1 REPLY 1
VIP Advocate
Re: Access problem from Inside to DMZ and outside to DMZ
The Access-rules should be similar to what you have on the ASA version 8.3+. You do not need a NAT to go from inside to DMZ. You can however add a NAT exempt to exempt inside to DMZ traffic from any translation.
DMZ to outside would require an Auto NAT rule. Also, an ACL would be needed from Outside to DMZ to allow internet users to access your public DMZ servers.
It would be good if you can show us an example of what you have configured and what is not working.
