Allowing an IPSEC conn through and NAT it
Hi there,
Was wondering if someone could point me in the right direction on this as I am fairly new to the security field.
I would like to only allow IPSEC connections through one of the public IP address on the ASA (ver 8.2(5)) outside interface. NAT it to a private address and route it out to the DMZ where there is a server for the IPSEC to terminate on.
Any help on achieving this would be great.
alexis
http://www.netpacket.co.uk/ http://www.blog.netpacket.co.uk/
Adeolu Owokade
Hi Alexis,
The configuration below should work based on your ASA version.
You need to configure static NAT for the private to public translation:
static (DMZ,OUTSIDE) <public IP> <private IP> netmask 255.255.255.255
Then you need to allow the IPsec protocols through an ACL applied on the outside:
access-list OUTSIDE-IN permit udp any host <public IP> eq 500
access-list OUTSIDE-IN permit udp any host <public IP> eq 4500
access-group OUTSIDE-IN in interface OUTSIDE
UDP port 4500 is necessary because NAT is involved.
Let me know if this helps.
Adeolu Owokade
Hi Alexis,
Thanks for the help Adeolu .. took a while to actualy get round to implementing it.
alexis
