Allowing Riverbed Option Sets
johng231
Level 3
Level 3
Hello-
I've created a policy map to allow TCP probe options 76 - 78 on the ASA Firewall for our Riverbed appliance.
Here is the setup:
access-list tcp-traffic line 1 extended permit tcp any any
class-map tcp-traffic
 match access-list tcp-traffic
tcp-map allow-probes
  tcp-options range 76 78 allow
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ils
  inspect dns preset_dns_map
 class tcp-traffic
  set connection random-sequence-number disable
  set connection advanced-options allow-probes
 show service-policy
Global policy:
  Service-policy: global_policy
    Class-map: inspection_default
      Inspect: ftp, packet 87626, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: h323 h225 _default_h323_map, packet 0, drop 0, reset-drop 0, v6-fail-close 0
               tcp-proxy: bytes in buffer 0, bytes dropped 0
      Inspect: h323 ras _default_h323_map, packet 1, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: netbios, packet 2155, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: rsh, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: rtsp, packet 350078, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: sqlnet, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: sunrpc, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: tftp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: sip , packet 2470, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: xdmcp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: ils, packet 190, drop 0, reset-drop 0, v6-fail-close 0
      Inspect: dns preset_dns_map, packet 19969072, drop 31696, reset-drop 0, v6-fail-close 0
    Class-map: tcp-traffic
      Set connection policy: random-sequence-number disable
        drop 0
      Set connection advanced-options: allow-probes
        Retransmission drops: 0                   TCP checksum drops : 0
        Exceeded MSS drops  : 0                   SYN with data drops: 0
        Invalid ACK drops   : 473                 SYN-ACK with data drops: 0
        Out-of-order (OoO) packets : 79504708     OoO no buffer drops: 206534
        OoO buffer timeout drops : 2590886        SEQ past window drops: 61463
        Reserved bit cleared: 0                   Reserved bit drops : 0
        IP TTL modified     : 0                   Urgent flag cleared: 0
        Window varied resets: 0
        TCP-options:
          Selective ACK cleared: 17               Timestamp cleared  : 130
          Window scale cleared : 1
          Other options cleared: 1060
            Opt 30: 792         Opt 38: 212         Opt 76: 56
          Other options drops: 0
Why am I seeing opt 76 showing up with 56 as the hit counts? I know most of the traffic is being optimized but some are showing in the Riverbed logs as being filtered on the option set. Some of the packets are being reset.  Opt 30 and 38 are not specified in the policy so I understand it being here. Can someone confirm my policy setup is correct?
ASA Software Version 9.1.(4)
Thanks in advance.
John
0 Replies 0
