anyconnect 4 SSLVPN and dual ISP configuration
Massimoriboli
Hi all,
i had a problem that was discussed a lot i think.
I have to migrate our active/standby firewall configuration in one single firewall and dual ISP configuration.
My question is about the Anyconnect SSLVPN.
Can someone give me an example about the right configuration to deploy on the ASA if i loose the connectivity on the first ISP ?
I have to deploy the webvpn on both line ?
Best Regards
Massimo Riboli
best Regards
You need to enable webvpn on both interfaces and then setup SLA tracking so that default route switches if the next hop out outside1 interface fails.  You will also need to create an AnyConnect profile that specifies the primary connection in the Server List and the backup connection in the Backup Servers section
Please remember to select a correct answer and rate helpful posts
