Welcome to Cisco Firewalls Community
279
Beginner
ANyconnect and remote VPN
Hi all,
I have a requirement to connect around 300 users to my network , I have a ASA 5555X available.
If I have to use general remote VPN which client software I need to use?
When i checked any connect license cost it was way high for me to afford for this project.
. What are some of the advantages in any connect vs the normal remote VPN?
. Do I need any license to enable 300 users VPN?
BS
1 ACCEPTED SOLUTION
Enthusiast
Re: ANyconnect and remote VPN
you better go with L-AC-PLS-LIC= and select 300, 5Y service.
8 REPLIES 8
Enthusiast
Hi, you can use 2 vpn clienta with cisco.
1- cisco vpn client (end of life)
2 - anyconnect client - need license. You can use VPN only license other than apex or plus license. That will be cheaper
Beginner
Hi Kasun,
Thanks.
Could you please provide some of the part number so that I can read about it
VIP Advisor
here is the ordering guide for you :
https://www.cisco.com/c/dam/en/us/products/collateral/security/anyconnect-og.pdf
BB
*** Rate All Helpful Responses ***
Beginner
Hi Balaji,
Thanks.
My confusion is which one to select for a 5 year use for around 300 users?
When i copy paste these in CCW its not listing.
Rising star
would be best for you if you approach your cisco gold/silver partner they would help you to get this sorted.
please do not forget to rate.
Enthusiast
What is your country.i can help with BoM.
Enthusiast
Beginner
Thanks Kasun.
it worked in my CCW. able to select the number of required licenses.
Appreciate your help.
