ASA 5505 boot problem
aprottob1974
I have a problem with a firewall ASA 5505. I erased the flash via command line.
Then there's what I did:
Rebooting ....
CISCO SYSTEMS
Embedded BIOS Version 1.0 (12) 13 08/28/08 15:50:37.45
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
  00 01 00 1022 2080 Host Bridge
  00 01 02 1022 2082 Chipset En / Decrypt 11
  00 0C 00 1148 4320 Ethernet 11
  00 0D 00 177D 0003 Network En / Decrypt 10
  00 0F 00 1022 2090 ISA Bridge
  00 0F 02 1022 2092 IDE Controller
  00 0F 03 1022 2093 Audio 10
  00 0F 04 1022 2094 Serial Bus 9
  00 0F 05 1022 2095 Serial Bus 9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0 (12) 13) # 0: Thu Aug 28 15:55:27 PDT 2008
Platform ASA5505
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Boot interrupted.
Ethernet0 / 0
MAC Address: 0024.c49e.7efb
Link is UP
Use? for help.
rommon # 1> set
ROMMON Variable Settings:
   ADDRESS = 192.168.1.1
   SERVER = 192.168.1.2
   GATEWAY = 0.0.0.0
   PORT = Ethernet0 / 0
   = Untagged VLAN
   IMAGE = asa902-k8.bin
   CONFIG =
   LINKTIMEOUT = 20
   PKTTIMEOUT = 4
   RETRY = 20
rommon #5> tftpdnld
  ADDRESS=192.168.1.1
  SERVER=192.168.1.2
  GATEWAY=0.0.0.0
  PORT=Ethernet0/0
  VLAN=untagged
  IMAGE=asa902-k8.bin
  CONFIG=
  LINKTIMEOUT=20
  PKTTIMEOUT=4
  RETRY=20
tftp asa902-k8.bin@192.168.1.2
Received 27611136 bytes
Launching TFTP Image...
Cisco Security Appliance admin loader (3.0) #0: Thu Feb 21 13:10:34 PST 2013
sumval(0x7a4 ) chksum(0x0   )md5(0x41130662 0xeacd779e 0x367c620f 0xa940e651)
md5(0x1dc0f999 0x599b1643 0x10101012 0xd50a8b8d)
Checksum verification on install image failed.
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)13 08/28/08 15:50:37.45
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
00  01  02   1022   2082  Chipset En/Decrypt 11
00  0D  00   177D   0003  Network En/Decrypt 10
Cisco Systems ROMMON Version (1.0(12)13) #0: Thu Aug 28 15:55:27 PDT 2008
Platform ASA5505
Launching BootLoader...
Default configuration file contains 1 entry.
Searching / for images to boot.
No images in /
Error 15: File not found
unable to boot an image
No images in /
Failsafe booting engaged.
No images in /
CISCO SYSTEMS
Low Memory: 632 KB
High Memory: 251 MB
PCI Device Table.
Platform ASA5505
Boot interrupted.
Ethernet0/0
Link is UP
Use ? for help.
rommon #0>
How can I do to recover the device?
Keeps rebooting endlessly!
Thank you.
Andrea
efuller
When the checksum fails, either the IOS image you are trying to load is corrupted (or incomplete) or the tftp download corrupted the image.
I would start by using an older, smaller image. Such as 8.2(5). Tftp that image to get the ASA booted, then upgrade to 9.0(2).
