Welcome to Cisco Firewalls Community
573
Beginner
Asa 5505 not forwarding RDP
Hello everyone,
I have an ASA 5505 and I cant get it to forward RDP, but I do get hits so Something does work.
I have attached my configuration. Can someone help me with this please? Just need to forward the RDP (Remote Desktop Protocol) to 10.0.20.2
Nathan
Everyone's tags (2)
1 ACCEPTED SOLUTION
Advocate
Hi Jonathan,
Sorry but you are missing quite a bit of configuration, you would need the following:
static (inside,outside) tcp interface 3389 10.0.20.2 3389
access-list 110 permit tcp any interface outside eq 3389
This should give you the access.
And then try to RDP on the outside interface of the ASA, if you have any free public ip, you can use that as well to access the RDP. This is only if you are trying to RDP from an IP on the internet.
Hope that helps.
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
1 REPLY 1
Advocate
Hi Jonathan,
Hope that helps.
Varun Rao
Security Team,
Cisco TAC
Content for Community-Ad
FusionCharts will render here
