04-30-2019 06:58 AM - edited 02-21-2020 09:05 AM
I'm struggling to set up an IKEv1 IPsec connection from a 3G router to an ASA 5506. The same VPN with a 5505 works perfectly.
Among other things, sh ver shows me this message:
The Running Activation Key feature: 2 security contexts exceed the limit on the platform, reduced to 0 security contexts
What does it mean?
This is the entire sh ver output:
Hardware: ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores) Internal ATA Compact Flash, 8000MB BIOS Flash M25P64 @ 0xfed01000, 16384KB Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1) Number of accelerators: 1 1: Ext: GigabitEthernet1/1 : address is 502f.a850.205c, irq 255 2: Ext: GigabitEthernet1/2 : address is 502f.a850.205d, irq 255 3: Ext: GigabitEthernet1/3 : address is 502f.a850.205e, irq 255 4: Ext: GigabitEthernet1/4 : address is 502f.a850.205f, irq 255 5: Ext: GigabitEthernet1/5 : address is 502f.a850.2060, irq 255 6: Ext: GigabitEthernet1/6 : address is 502f.a850.2061, irq 255 7: Ext: GigabitEthernet1/7 : address is 502f.a850.2062, irq 255 8: Ext: GigabitEthernet1/8 : address is 502f.a850.2063, irq 255 9: Int: Internal-Data1/1 : address is 502f.a850.205b, irq 255 10: Int: Internal-Data1/2 : address is 0000.0001.0002, irq 0 11: Int: Internal-Control1/1 : address is 0000.0001.0001, irq 0 12: Int: Internal-Data1/3 : address is 0000.0001.0003, irq 0 13: Ext: Management1/1 : address is 502f.a850.205b, irq 0 14: Int: Internal-Data1/4 : address is 0000.0100.0001, irq 0 15: Int: Internal-Data1/5 : address is 0000.0001.0003, irq 0 The Running Activation Key feature: 2 security contexts exceed the limit on the platform, reduced to 0 security contexts. Licensed features for this platform: Maximum Physical Interfaces : Unlimited perpetual Maximum VLANs : 30 perpetual Inside Hosts : Unlimited perpetual Failover : Active/Standby perpetual Encryption-DES : Enabled perpetual Encryption-3DES-AES : Enabled perpetual Carrier : Disabled perpetual AnyConnect Premium Peers : 4 perpetual AnyConnect Essentials : Disabled perpetual Other VPN Peers : 50 perpetual Total VPN Peers : 50 perpetual AnyConnect for Mobile : Disabled perpetual AnyConnect for Cisco VPN Phone : Disabled perpetual Advanced Endpoint Assessment : Disabled perpetual Shared License : Disabled perpetual Total TLS Proxy Sessions : 160 perpetual Botnet Traffic Filter : Disabled perpetual Cluster : Disabled perpetual This platform has an ASA 5506 Security Plus license. Serial Number: XXXXXX Running Permanent Activation Key: 0xXX 0xXX 0x5831fde0 0xXX 0xXX Configuration register is 0x1 Image type : Release Key Version : A
Thanks and ciao
04-30-2019 11:26 AM
By Default ASA License support 2 contexts, Have you created any Context in FW ?
post output :
show context
05-02-2019 04:36 AM
There is no such command:
MyFw# show context ^ ERROR: % Invalid input detected at '^' marker. MyFw# show co MyFw# show co? community-list compression configuration configuration conn console-output controller coredump counters MyFw#
