Welcome to Cisco Firewalls Community
1434
Beginner
ASA 5506 In routed mode BVi is not available.
Hi I am using  ASA5506 v9.6(4) and I want to create multiply interface in one vlan / BVi, so I can use those interface in a single subnet.
In transparent mode Bvi is working but I need my ASA in routed mode for using vpn and other feature.
So is there any other way to do it ? Please help me!
Thanks.
1 ACCEPTED SOLUTION
VIP Advocate
Re: ASA 5506 In routed mode BVi is not available.
BVI was introduced in version 9.7.x.  You need to upgrade your ASA to use this feature.
Please remember to rate and select a correct answer
3 REPLIES 3
VIP Advocate
Beginner
Thanks Marius. It's the only option now left.
Engager
hi,
marius is correct. you could leverage the BVI feature on the 9.7 code.
see helpful link:
http://wannabecybersecurity.blogspot.com/2018/10/cisco-asa-5506w-x-basic-configuration.html
