Welcome to Cisco Firewalls Community
521
Beginner
ASA 5510 Hairpin/U-Turn Traffic to escape tunnel to public internet
I have an interesting request from a remote-site not wanting to allow access to a public facing IP.  We have a tunnel between their ASA & ours which hairpins traffic to 2 networks out the outside interface.
(IPs have been changed to protect the innocent)
From the remote-site perspective, they are pointing a host to 10.0.0.1 & 10.0.0.2, then NATing on the edge of their tunnel to destinations 172.16.0.1 & 172.16.0.2 (to keep everything pointed to private IPs).
Our outside interface has a private IP on the 172.16.0.x/24 network.
172.16.0.1 is the real IP of SERVER1
172.16.0.2 is an unused dummy IP on the same subnet, & is only used to NAT to the public I'll refer to as 8.8.8.8.
All traffic is initiated from the client's private network, so I would think the stateful TCP connections should allow this to work, & I was able to prove this works in my ASA lab with a simple hairpin nat, but it doesn't seem to be working on the real network with a tunnel involved.  Is there something I'm missing that I need to do to allow this to work?  Packet-tracer shows the NATing is working as expected, but it claims a deny at the end of the hairpin because it's no longer tunneled traffic once it's headed for the public internet.  I've seen in other forums that this is a normal limitation to the packet-tracer tool in regards to tunneled traffic.
I have same-security-traffic permit inter/intra-interface enabled.  Either one of my nat statements "should" work, but it doesn't seem to be doing the trick.
I've included a generic firewall in the drawing to show our public IP for the L2L tunnel is passed through another firewall to us, & that this firewall has the 172.16.0.0/24 network connected to it.
What am I missing to make this work as desired?
 (EDIT/update with details on my ASA)
object network PRIV-IP
 host 172.16.0.2
object network PUB-IP
 host 8.8.8.8
object network REMOTE-HOST
 host 192.168.1.10
object network REMOTE-HOST2
 host 192.168.1.11
object-group network REMOTE-SITE
 network-object object REMOTE-HOST
 network-object object REMOTE-HOST2
access-list TUNNEL-ACL extended permit ip object SERVER1 object-group REMOTE-SITE
access-list TUNNEL-ACL extended permit ip object PRIV-IP object-group REMOTE-SITE
crypto map outside_map 10 match address TUNNEL-ACL
nat (outside,outside) source static REMOTE-HOST REMOTE-HOST destination static PRIV-IP PUB-IP
[should also work?] nat (outside,outside) source dynamic REMOTE-HOST interface destination static PRIV-IP PUB-IP
 nat (outside,outside) dynamic interface
5 REPLIES 5
VIP Advocate
Re: ASA 5510 Hairpin/U-Turn Traffic to escape tunnel to public internet
Are you NATing at both firewalls? 10.0.0.2 to 172.16.0.2 and then again 172.16.0.2 to 8.8.8.8?
Please remember to rate and select a correct answer
Beginner
yes.
 Updated original post with more details, but here's the essential nat flow:
10.0.0.2 > 172.16.0.2 (tunnel) 172.16.0.2 > 8.8.8.8
Frequent Contributor
Can you add route-lookup at the end of the nat statement?
Beginner
No, it will not accept that command.  I think I can only use that if I'm keeping the NATs the same on the statement.
Sorry for the delay- I was waiting on feedback if I could have the remote ASA NAT to the real IP before the tunnel but was just denied, so I'm back to trying to making this thrice-nat thing work again.
Beginner
UPDATE:
I ended up routing this traffic Inside instead of haripinning.  Funny thing is it still didn't work until I removed the network objects referenced in the NAT statement & added them back.  Since that fixed it, I didn't care to try it with the hairpin again to see if that was really all I needed to do.
