04-08-2011 03:09 AM - edited 03-11-2019 01:18 PM
I'm new to firewall using ASA 5510. I am wondering can somebody point me to the right direction on how can I have a redundancy over two ASA 5510. Hardware load balancing and IP Load balancing, just like HSRP or GLBP. Below is my diagram.
----- INTERNET------
ASA ASA
3560-------------------3560
PRIVATE NETWORK
THANK YOU IN ADVANCE.
04-08-2011 05:08 PM
You can try to use an active/active failover environment with multiple context configuration.
Please check the following link for documentation and configuration example:
Hope it helps!
~Rub
04-08-2011 11:53 PM
I can't access the url. It says its forbidden. Please advise.
