ASA 5510 PROBLEM.
antrikos_kal
Hello there,
the nat (inside) 1 10.1.1.0 255.255.255.0 and global (outside) 1 interface are deprecated and I don't know what to do after the IOS upgrade.I don't have access to the the internet.My show run is the following.Please help.
ciscoasa(config)# show run
: Saved
: Serial Number: JMX1225L1LS
: Hardware: ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1599 MHz
ASA Version 9.1(7)32
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0/0
speed 100
duplex full
nameif outside
security-level 0
ip address dhcp
interface Ethernet0/1
speed 100
duplex full
nameif inside
security-level 100
ip address 10.1.1.2 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
boot system disk0:/asa917-32-k8.bin
boot config disk0:/startup-1.cfg
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd ping_timeout 750
dhcpd address 10.1.1.32-10.1.1.63 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:29045e32ddc109ac154653d1337ec445
: end
4 Accepted Solutions
try this.
object network INSIDE
subnete 10.1.1.0 255.255.255.0
nat (inside,outside) dynamic interface
please do not forget to rate.
you ASA is also acting as DHCP server you config are like this
dhcpd enable inside
just add this command
dhcpd 8.8.8.8
interface ethx/x
 nameif outside
 ip address dhcp setroute
 no shut.
ASA 5510 is end of life end of support link is https://www.cisco.com/c/en/us/products/collateral/security/asa-5500-series-next-generation-firewalls/eol_C51-727283.html
even the security module is end of life and end of support. cisco refresh the ASA series and called them ASA-X. instead of using the legacy IPS and gone for firepower.
here is the link https://www.cisco.com/c/en_uk/products/security/asa-firepower-services/index.html
if you setting up for lab environment that fair. but for production network i would not recommand this. as this is old series.
11 Replies 11
try this.
Nope, private network w/o internet access.it shows I am connected on the private LAN.Also I do have ASDM now.
show run follows
: Saved
: Hardware:   ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
hostname ciscoasa
names
 speed 100
 duplex full
 nameif outside
 security-level 0
 ip address dhcp
 speed 100
 duplex full
 nameif inside
 security-level 100
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
ftp mode passive
object network inside
 subnet 10.1.1.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
no failover
asdm image disk0:/asdm-781-150.bin
arp timeout 14400
http server enable
http 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 208.67.222.222 208.67.220.220
dhcpd enable inside
username whiterabbit password Q./RmFu77Ejvfvpg encrypted privilege 15
call-home
 profile CiscoTAC-1
  no active
Cryptochecksum:a299bc453b2b0013ecd1f29df5bc2c54
: end
ciscoasa(config)#
Do you think it's a dns issue?i had dns issues in the past also.maybe it doesn't resolve names.
dhcpd enable inside
dhcpd 8.8.8.8
Follows more info, btw the outside is down because I connected directly to my router now.
ciscoasa(config)# show int
Interface Ethernet0/0 "outside", is down, line protocol is down
  Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
        Full-Duplex, 100 Mbps
        Input flow control is unsupported, output flow control is off
        MAC address 0021.554f.35bc, MTU 1500
        IP address 192.168.1.5, subnet mask 255.255.255.0
        44 packets input, 7708 bytes, 0 no buffer
        Received 19 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 pause input, 0 resume input
        0 L2 decode drops
        7 packets output, 1508 bytes, 0 underruns
        0 pause output, 0 resume output
        0 output errors, 0 collisions, 2 interface resets
        0 late collisions, 0 deferred
        2 input reset drops, 0 output reset drops, 0 tx hangs
        input queue (blocks free curr/low): hardware (255/255)
        output queue (blocks free curr/low): hardware (255/255)
  Traffic Statistics for "outside":
        42 packets input, 6578 bytes
        7 packets output, 1292 bytes
        35 packets dropped
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 0 pkts/sec,  1 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute drop rate, 0 pkts/sec
Interface Ethernet0/1 "inside", is up, line protocol is up
        Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
        MAC address 0021.554f.35bd, MTU 1500
        IP address 10.1.1.2, subnet mask 255.255.255.0
        764 packets input, 77561 bytes, 0 no buffer
        0 L2 decode drops
        701 packets output, 142566 bytes, 0 underruns
        0 output errors, 0 collisions, 1 interface resets
        16 input reset drops, 0 output reset drops, 0 tx hangs
        input queue (blocks free curr/low): hardware (255/250)
        output queue (blocks free curr/low): hardware (255/240)
  Traffic Statistics for "inside":
        748 packets input, 61663 bytes
        701 packets output, 128036 bytes
        284 packets dropped
      5 minute input rate 0 pkts/sec,  18 bytes/sec
      5 minute output rate 0 pkts/sec,  78 bytes/sec
Interface Ethernet0/2 "", is administratively down, line protocol is down
  Hardware is i82546GB rev03, BW 100 Mbps, DLY 100 usec
        Auto-Duplex, Auto-Speed
        Available but not configured via nameif
        MAC address 0021.554f.35be, MTU not set
        IP address unassigned
        0 packets input, 0 bytes, 0 no buffer
        Received 0 broadcasts, 0 runts, 0 giants
        0 L2 decode drops
        0 packets output, 0 bytes, 0 underruns
        0 input reset drops, 0 output reset drops, 0 tx hangs
Interface Ethernet0/3 "", is administratively down, line protocol is down
        MAC address 0021.554f.35bf, MTU not set
        0 L2 decode drops
Interface Management0/0 "", is administratively down, line protocol is down
  Hardware is i82557, BW 100 Mbps, DLY 100 usec
        Input flow control is unsupported, output flow control is unsupported
        MAC address 0021.554f.35c0, MTU not set
        0 L2 decode drops
        0 babbles, 0 late collisions, 0 deferred
        0 lost carrier, 0 no carrier
        input queue (curr/max packets): hardware (0/0) software (0/0)
        output queue (curr/max packets): hardware (1/0) software (0/0)
ciscoasa(config)# show route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
C 10.1.1.0 255.255.255.0 is directly connected, inside
ciscoasa(config)# show ip
System IP Addresses:
Interface Name IP address Subnet mask Method
Ethernet0/0 outside 192.168.1.5 255.255.255.0 DHCP
Ethernet0/1 inside 10.1.1.2 255.255.255.0 CONFIG
Current IP Addresses:
interface ethx/x
 nameif outside
 no shut.
That's already setted up.It doesn't have internet access.
You are missing the default route. Will you please configure "route outside 0.0.0.0 0.0.0.0 your_router_ip_address" and check if there is any progress.
Best regards,
Antonin
ok!i will try that, thank you very much, that you all!really appreciate it.i also have an SSM-10 module i managed to reset it's password but i don't know how to configure it even it's basics.Also i noticed it says has no LICENSE.Is that a problem in it's function?My asa 5510 has a security plus license but the module hasn't at all.But it says up up when  i show module 1.
Since, I got rid of the catalysts switches I have had problems, I use some fake switches.i switched cables and powered off the switches and POOF!I have internet access.Thanks a lot.
