11-06-2013 12:07 PM - edited 03-11-2019 08:01 PM
Fairly new with ASA's, and could use a little help. I have an ASA5515 configured as a DHCP server in a customer environment. Clients that obtain their IP's via DHCP lose network connectivity after a short period of time, however clients that are staticly connected still have network connectivity.
Attached are output from the show version and show run commands.
Client is using Ruckus Wireless with an 1106 controller and 9 AP's, 2 unmanaged switches and Windows XP/7 clients. Not a very complicated network.
Any ideas would be greatly appreciated.
Jake
11-08-2013 11:36 AM
The static clients not losing connectivity is what is really confusing me. Maybe the lease time? A rogue dhcp server? Any way to check this on the Asa?
11-08-2013 12:00 PM
Dont really know what the problem would be.
It seems to me that there are a lot of unneeded DHCP configurations on the unit atleast
To my understanding the below 4 configurations are only needed if your WAN interface was acting as a DHCP Client. I mean a situation where your ASA would get its public IP address through DHCP from the ISP instead of the current setting which is static.
dhcp-client client-id interface WAN
dhcpd auto_config WAN
dhcpd auto_config WAN interface management
dhcpd auto_config WAN interface LAN
The below to my understanding is not needed since you have already set the interface specific DNS servers
dhcpd dns 99.99.99.53 99.99.99.153
The below to my understanding is not needed as you dont have any DynDNS configurations on the ASA.
dhcpd update dns both interface LAN
Seems to me tha the below configuration configured DNS server correct? Though you already have a configuration for the LAN interface with the "dhcpd dns" configuration.
dhcpd option 6 ip 8.8.8.8 4.2.2.2 interface LAN
I don't know if these really have anything to do with your problem but I just thought that they were not needed.
It seems to me that the only configurations you would need for basic DHCP would be
dhcpd address 192.168.123.100-192.168.123.249 LAN
dhcpd dns 8.8.8.8 4.4.2.2 interface LAN
dhcpd enable LAN
Is the connectivity cut complete? I mean can you even ping internal gateway of the users? Are you able to ping anything with IP address directly?
I guess you could choose one DHCP IP address as a test and capture its traffic and see what you see in the traffic capture at the time before and after the problem. You can do that probably on the client directly or perhaps also on the ASA
On the ASA the capture could be done with the following configuration
access-list CAPTURE permit ip host
access-list CAPTURE permit ip any host
capture CAPTURE type raw-data access-list CAPTURE interface LAN buffer 33500000 circular-buffer
To view if anything is hitting the capture use the command
show capture
To show contents of the capture on the CLI use the command
show capture CAPTURE
To copy the capture to your computer so you can open it with Wireshark for example use the command
copy /pcap capture:CAPTURE tftp://x.x.x.x/CAPTURE.pcap
To remove the capture use the command
no capture CAPTURE
The ACL created has to be removed separately.
Does sound like an ASA problem to me but maybe the capture might tell something. Atleast you could confirm if the any traffic even reaches the ASA when the client is expiriencing problems.
Hope this helps
- Jouni
11-08-2013 04:44 PM
Thanks for your reply.
I made the edits you suggested, but then found what I think may have been causing the issue.
Customer had a user that was using his own wi-fi/router device in his office. We disconnected that device and things seem to be working fine!
