Welcome to Cisco Firewalls Community
509
Beginner
ASA 5515 second outside interface
Good day all, can someone advise what is the best way to go about setting up a second outside interface on ASA - reason behind is that we're trying to have a security alarm system have a dedicated internet feed, having 2 disabled interface on our ASA i figure i could bring one up and setup some sort of static NAT from Security system to internet.
Security alarm system is on its own subnet 192.168.7.x /24 and vlan of course - i want traffic from a specific IP to go out this new outside interface. Any help would be greatly appreciated, ACL and NAT info.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Participant
This can be achieved by using Policy Based Routing that is available in ASA version 9.4 and later.
Example configuration
interface GigabitEthernet0/2
 description ***New Outside Interface***
 nameif outside2
 security-level 0
 ip address x.x.x.x
object network security-system
 subnet 192.168.7.0 255.255.255.0
nat (inside,outside2) source dynamic security-system interface
access-list acl-security-system permit 192.168.7.0 255.255.255.0
route-map policy-route permit 10
 match ip address security-system
 set ip next-hop x.x.x.x <----- IP address of new outside2 interface gateway
interface GigabitEthernet0/1
 description ***Inside Interface***
 nameif inside
 security-level 100
 ip address x.x.x.x
 policy-route route-map policy-route
You can find further details of PBR in the following document as well as some additional  example configs.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa94/config-guides/cli/general/asa-94-general-config/route-policy-based.pdf
I hope that this helps
1 REPLY 1
Participant
 nameif outside2
 security-level 0
 ip address x.x.x.x
 nameif inside
 security-level 100
 ip address x.x.x.x
Content for Community-Ad
FusionCharts will render here
