Hi All,
I just installed a secondary firewall in act/standby setup and noticed that it seems to be overheating.
See the output of show env command below. It seems that the CPU is at 75* but the Chassis fan is just at 2600rpm. And this is on a firewall that just sits there in standby, 0% cpu usage.
On my other firewalls (that are actually doing stuff) the chassis fan is at ~4000rpm with 30* cpu temperature.
Cooling Fans:
Chassis Fans:
Chassis Fan: 2640 RPM - OK
Temperature:
Processors:
Processor 1: 75.0 C - Critical (CPU Core Temperature)
Accelerators:
Accelerator 1: 40.0 C - OK (Accelerator Temperature)
Chassis:
Ambient 1: 40.0 C - OK (Chassis Temperature)
Motherboard:
Ambient: 40.0 C - OK (Chassis Temperature)
Voltage:
Channel 1: 12.364 V - OK (12V)
Channel 2: 5.000 V - OK (5V)
Channel 3: 1.351 V - OK (1.35V_CPU)
Channel 4: 0.982 V - OK (1.0V_VCC)
Channel 5: 1.017 V - OK (1.0V_VNN)
Channel 6: 1.802 V - OK (1.8V_CPU)
Channel 7: 1.071 V - OK (1.07V_CPU)
Channel 8: 0.849 V - OK (0.85V)
Channel 9: 3.344 V - OK (3.3V)
Channel 10: 2.531 V - OK (2.5V)
Channel 11: 1.510 V - OK (1.5V)
Channel 12: 1.217 V - OK (1.2V)
Channel 13: 0.899 V - OK (0.9V)
Channel 14: 1.355 V - OK (1.35V_DDR)
Channel 15: 3.347 V - OK (3.3V_STBY)
ALARM CONTACT 1
Status: not asserted
Description: external alarm contact 1
Severity: minor
Trigger: closed
ALARM CONTACT 2
Description: external alarm contact 2
Severity: minor
Trigger: closed
Driver Information:
Status : RUNNING
Cisco Adaptive Security Appliance Software Version 9.8(2)17
Firepower Extensible Operating System Version 2.2(2.63)
Device Manager Version 7.9(1)
Compiled on Thu 04-Jan-18 10:21 PST by builders
System image file is "disk0:/asa982-17-lfbff-k8.SPA"
Config file at boot was "startup-config"
DBFirewall up 3 hours 11 mins
failover cluster up 19 days 1 hour
Hardware: ASA5516, 8192 MB RAM, CPU Atom C2000 series 2416 MHz, 1 CPU (8 cores)
Internal ATA Compact Flash, 8000MB
BIOS Flash M25P64 @ 0xfed01000, 16384KB
