12-07-2018 07:40 PM - edited 02-21-2020 08:32 AM
Since I've upgraded from the ASA5505 to the ASA5516-X, my Voip adapter no longer works. It worked fine with my old ASA5505 but not since I've upgraded.
My VOIP adapter is a SPA122 from Cisco. It's communicating via UDP on port 5060. The settings on the SPA include "Nat mapping enable - yes, nat keep alive enable - yes".
The problem now is that my phone calls all last EXACTLY 20 seconds. After this, the call just drops cold. I checked the logs on the ASA and I can't see any messages about blocking or anything else.
I have checked the default inspection rules and SIP is listed there and enabled for UDP and TCP.
Please let me know what can be the problem here.
Thanks.
Solved! Go to Solution.
12-07-2018 11:47 PM
12-07-2018 11:47 PM
12-08-2018 09:05 AM
This worked. Calls through voip are back to normal.
Thank you!
12-08-2018 08:58 AM
can we have look your configuration, since you have mentioned call going through and and it was not last for 20min or so,
