ASA 5520 Issue
FinningCL
         I have an ASA 5520 and it's show me this error "mount: mounting /dev/hda1 on /mnt/disk0 failed: No such device or address"
How I can fix it?
Can you give me a procedure?
Hello Hugo,
Did you manage to copy the IOS to disk0: before reloading the ASA . from rommon using boot command are you able to boot the ASA ?
from rommon, perform dir or dir disk0: to see whether you have image on the disk.. if its not there.. follow the beloe link  to upoad the IOS to ASA
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/admin_trouble.html
please let me know if you need further help
Harish
15 Replies 15
Hello Hugo,
you are getting this error while you enter some command or in what situation this is happening ?
harish.
Hi Harish,
Thanks for your help. This error appear when I trying to upload the image with the configuration and after restar the console show me this error.
Hello Hugo,
could you run  the command   fsck disk0:  from  exec mode and try to upload the config/image and see whether you are getting this error
regards
Harish.
I ran the command and the result is
ciscoasa# fsck disk0
Unsupported file system type!
%Error checking disk0: (No such file or directory)
When the ASA is restarting,..
Launching TFTP Image...
Cisco Security Appliance admin loader (3.0) #0: Wed Jul  1 19:16:43 MDT 2009
Platform ASA5520
Loading...
dosfsck 2.11, 12 Mar 2005, FAT32, LFN
open /dev/hda1:No such device or address
dosfsck(/dev/hda1) returned 1
Set 'tap0' persistent and owned by uid 0
IO memory 85360640 bytes
Processor memory 345288704, Reserved memory: 62914560 (DSOs: 0 + kernel: 6291456
0)
Total SSMs found: 0
Total NICs found: 7
mcwa i82557 Ethernet at irq 11  MAC: 0024.14d0.3d2b
mcwa i82557 Ethernet at irq  5  MAC: 0000.0001.0001
i82547GI rev00 Gigabit Ethernet @ irq11 dev 1 index 05 MAC: 0000.0001.0002
i82546GB rev03 Gigabit Ethernet @ irq09 dev 2 index 03 MAC: 0024.14d0.3d2f
i82546GB rev03 Gigabit Ethernet @ irq09 dev 2 index 02 MAC: 0024.14d0.3d2e
i82546GB rev03 Gigabit Ethernet @ irq09 dev 3 index 01 MAC: 0024.14d0.3d2d
i82546GB rev03 Gigabit Ethernet @ irq09 dev 3 index 00 MAC: 0024.14d0.3d2c
INFO: Unable to read firewall mode from flash
       Writing default firewall mode (single) to flash
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
This activation key is not valid.
Use default settings only
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : [1]CN1000-MC-BOOT-2.00
                            SSL/IKE microcode:
CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.04
Cisco Adaptive Security Appliance Software Version 8.2(1)4
  ****************************** Warning *******************************
  This product contains cryptographic features and is
  subject to United States and local country laws
  governing, import, export, transfer, and use.
  Delivery of Cisco cryptographic products does not
  imply third-party authority to import, export,
  distribute, or use encryption. Importers, exporters,
  distributors and users are responsible for compliance
  with U.S. and local country laws. By using this
  product you agree to comply with applicable laws and
  regulations. If you are unable to comply with U.S.
  and local laws, return the enclosed items immediately.
  A summary of U.S. laws governing Cisco cryptographic
  products may be found at:
  If you require further assistance please contact us by
  sending email to export@cisco.com.
  ******************************* Warning *******************************
Copyright (c) 1996-2009 by Cisco Systems, Inc.
                Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
                Cisco Systems, Inc.
                170 West Tasman Drive
                San Jose, California 95134-1706
Insufficient flash space available for this request:
  Size info: request:32 free:0  delta:32
open or write(ffsdev/2/write/32) failed
Could not initialize system files in flash.
Al querer ver lo que tiene la flash me aparece lo siguiente:
ciscoasa# show flash:
--#--  --length--  -----date/time------  path
  429  0           Sep 26 2012 03:34:36  crypto_archive
  416  0           Sep 26 2012 03:34:28  log
0 bytes total (0 bytes free)
Y al reiniciar el ASA aparece lo siguiente:
Launching BootLoader...
Default configuration file contains 1 entry.
Boot mode is 1. Default entry is 1.
Searching / for images to boot.
No images in /
Error 15: File not found
unable to boot an image
No images in /
Failsafe booting engaged.
No images in /
Hello Hugo,
If you get the following while performing the disk0 check
ciscoasa# fsck flash:
%Error checking flash: (No such file or directory)
ciscoasa#
Then we will need to proceed to format the flash and upload a new image.
Any other question..Sure.. Just remember to rate all of my answers.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
I don't have the issues with the flash. Is with the disk
infact You need to format disk0:  and copy a new image
regards
Harish.
Harish,
I formatted the fdisk, but now when I am restarting the ASA showme ROMMON and it doesn't start the IOS automaticaly.
What can I do?
Hello Hugo,
Harish
Harish,
The issue was solved. Thanks for yous support.
Hugo
how solved it?? i have a same problem!!!
This discussion thread is 6 years old. Please start a new one describing your problem in detail.
disk:0 =flash
You should format the flash Hugo,
Sorry to tell you that
Julio Carvajal
I understand, can you tell me what commands I must use? I know that is format disk(o) Is that correct?
