ASA 5520 Upgrade 8.0(3) to 8.3.1 question
troymaki
I know there is a required 2GB memory upgrade to go to 8.3.
Is it possible to do the upgrade in the following order, to minimize downtime?
1 - install 8.3.1
2 - shutdown the ASA
3 - install memory upgrade
4 - power ASA on to complete the upgrade
Or do I have to install the memory first and then do the upgrade?
6 Replies 6
ksuchewie
Download image
upload to asa
set boot image
-----downtime
power-down asa
install memory
power-on asa
laptev.valery
I have very simalar question.
I am planning to migrate from asa 5520(8.0(4)) to 5520(8.3.1)
we have failover
ram512
flash256
we gonna upgrate memmory
Do i need to make any changes in config of ASA to make work same rules on new software?
maybe some links? or sudgestions?*
Here is the ASA 8.3 migration guide http://conft.com/en/US/docs/security/asa/asa83/upgrading/migrating.html
Though the ASA should migrate smoothly...without any intervention as it comes up in 8.3.
I hope it helps.
PK
I just did the upgrade on our main 5520 two days ago. I've upgraded two 5520's and one 5505 to 8.3.1 and the last one was the only one that had a couple of NAT issues.  They were pretty easy to figure out.  Just follow the upgrade guide and you will be fine.
http://www.cisco.com/en/US/docs/security/asa/asa83/upgrading/migrating.html
check the cisco website for ram requirement for that IOS, i tried upgrading my 5520 from 804 to 8.2...something and when i rebooted the device , it showed me error for not enough RAM  ( i have 512 mb ).
Please check that out before you upgrade.
thanks
manish
Allen P Chen
Level 5
Level 5
Here is the link to the 8.3 Release Notes with the memory  requirements mentioned by the previous user.
http://www.cisco.com/en/US/docs/security/asa/asa83/release/notes/asarn83.html#wp37821
