03-15-2018 04:28 AM - edited 02-21-2020 07:31 AM
My ASA has 3 interfaces configured: inside, outside, DMZ. I can't access the DMZ network from the LAN and vice versa what should i do here is my config file ?
Hardware:ASA5525
ASA Version 9.2(2)4
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
xlate per-session permit tcp any4 any4
names
interface GigabitEthernet0/0
description CONNECTION TO Core switch
channel-group 10 mode active
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
description Connection To DMZ01
nameif DMZ
security-level 50
ip address 192.168.100.1 255.255.255.0
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/7
description Connection to ISP
shutdown
nameif outside
security-level 0
ip address x.x.x.x x.x.x.x
interface Port-channel10
lacp max-bundle 8
nameif inside
security-level 100
ip address 172.16.25.1 255.255.255.248
ftp mode passive
dns server-group DefaultDNS
access-list icmp_access extended permit icmp any any
access-list outside_access_in extended permit ip any any
pager lines 24
mtu inside 1500
mtu DMZ 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group outside_access_in global
router ospf 10
router-id 172.16.25.25
network 172.16.25.0 255.255.0.0 area 0
network 192.168.100.0 255.255.255.0 area 0
log-adj-changes
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map icmp-class
match default-inspection-traffic
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map icmp_policy
class icmp-class
inspect icmp
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect icmp
service-policy global_policy global
service-policy icmp_policy interface inside
service-policy icmp_policy interface DMZ02
service-policy icmp_policy interface outside
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly 8
subscribe-to-alert-group configuration periodic monthly 8
subscribe-to-alert-group telemetry periodic daily
03-15-2018 06:48 AM
03-17-2018 05:35 AM
03-19-2018 03:19 AM
