Welcome to Cisco Firewalls Community
321
Beginner
ASA 8.2 configuration for an ASA 9.1.(1) device
Hello, I have a configuration file from a 5510 running ASA ver 8.2
I have a brand new ASA5525 running ASA ver 9.1(1)
It is my understanding the configuration syntax is different between these versions
I need to take this config I have and somehow auto-format it to work with 9.1(1).  Upgrade is not an option since the firewall is already on 9.1(1)
Anyone know how would I go about this?
1 ACCEPTED SOLUTION
Hi,I think you can use this
I think you can use this Document to understand the Syntax changes and you will find the corresponding syntax for ASA 9.x as well.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa83/upgrading/migrating.html
Also , you can check out this Automated tool as well:-
http://www.tunnelsup.com/nat-converter
I would recommend going through and manually converting the configuration to prevent any errors.
Thanks and Regards,
Vibhor Amrodia
1 REPLY 1
Thanks and Regards,
Vibhor Amrodia
