ASA 8.4 NAT order question
jason.williams
In pre-8.3, NAT had a group number to match nat to global.
How do I do this in 8.4?  I need a default pat (0.0.0.0), but I also have specific pat for certain subnets.  How do I keep them from overlapping?  Will it check more specific nat statements first before it gets to more generic any any or 0.0.0.0?
Thanks.
Jason
Jouni Forss
Generally you should consider the following things with regarding NAT in 8.3 and newer software
  • NAT is broken into 3 sections on the ASA
    • Section 1 consists of Twice NAT configurations (also called Manual NAT)
    • Section 2 consists of NAT configurations configured under "object network"
    • Section 3 consists of Twice NAT (also called Manual NAT) configurations that have been moved to the last section with the parameter "after-auto" (configured right after the source and destination interface)
  • NAT has "line numbers" just like ACLs for Section 1 and Section 3 NAT configurations
    • Adding a new Twice NAT rule with a line number (right after source,destination interface) will move the existing rule and any after that 1 line number down. Without line number its added at the bottom (and might not apply)
  • NAT configured with "object network" doesnt not use "line numbers". Instead their use is based on how specific the rule is and the decision of the ASA what rule to use might be even as specific as the the alphabetic order of the "object network" names is
I suggest reading the following section of the Configuration Guide for your software. (And any related sections). They give some nice addiotional information about the NAT operations
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/nat_overview.html#wp1118157
Now lets take this example situation
  • You have alot of networks that fall into the whole 10.0.0.0/8 network
  • You want to give own NAT rules for some 10.x.x.x/yy subnets
The "catch all" Default PAT rule
object-group network DEFAULT-PAT-SOURCE
network-object 10.0.0.0 255.0.0.0
nat (inside,outside) after-auto source dynamic DEFAULT-PAT-SOURCE interface
Where
  • DEFAULT-PAT-SOURCE = Is the "object-group" that defines the networks that are used for this PAT configurations
  • after-auto = Moves this NAT rule to the last Section 3 (as mentioned in the start of the post, it should be a default rule if nothing else is configured)
  • interface = Is the parameter that will define that the destination interface of the NAT (outside) is used as PAT address
Now if we want to create a more specific rule in the Section 3 we could do the following
object-group network SPECIAL-PAT-SOURCE
network-object 10.10.10.0 255.255.255.0
object network PAT-ADDRESS
host 1.1.1.1
nat (inside,outside) 1 after-auto source dynamic SPECIAL-PAT-SOURCE PAT-ADDRESS
Where
  • SPECIAL-PAT-SOURCE = Again defines the source addresses/networks for the NAT/PAT
  • PAT-ADDRESS = Is used to define the new Public IP address since we can use the "interface" parameter (we want another IP address)
  • "1" = This is the crucial point. It moves the new NAT rule in Section 3 NAT rules to the top. Taking the place of the NAT configuration we configured first. Hence the new rule will be hit first and all remanining 10-networks will hit the default PAT rule that is now on line number "2"
    • Notice that the line numbers dont show in the CLI format of the configuration when using "show run nat". They only show on the CLI with "show nat" which doesnt really give a clear output
Example show command output from my ASA
ASA(config)# sh run nat
  • No NAT rule numbering
nat (LAN,WAN) after-auto source dynamic LAN-NETWORK interface
nat (WLAN,WAN) after-auto source dynamic WLAN-NETWORK interface
ASA(config)# show nat
  • Order of NAT configurations mentioned (and also the Section number)
Manual NAT Policies (Section 3)
1 (LAN) to (WAN) source dynamic LAN-NETWORK interface
    translate_hits = 0, untranslate_hits = 0
2 (WLAN) to (WAN) source dynamic WLAN-NETWORK interface
Hitcounts are 0 because I remotely reloaded the ASA earlier today and there are no hosts turned on behind it.
The above is not the only options naturally but its based on the way I configure NAT.
  • Section 1 (Manual NAT): Special NAT setups (VPN, possible partner DMZ connections etc)
  • Section 2 (Object NAT): Static NAT and Port Forward configurations (Static PAT)
  • Section 3 (Manual NAT): Default NAT/PAT rules for majority of the traffic through the ASA
Hopefully this answered your questions. Please rate or mark the question as answered if so. Naturally ask more if you need some clarifications or need to ask something more
- Jouni
