Welcome to Cisco Firewalls Community
888
Beginner
ASA 8.4 no connection one interface to another
Hi guys,
I'm stuck on a particular issue, I can see this in SYSLOG:
Deny TCP (no connection) from 192.168.112.x./x to 192.168.115.x/x flags SYN ACK  on interface inside
Teardown TCP connection 7844974 for fw-mgmt:192.168.115.x/x to inside:192.168.112.x/x duration 0:00:00 bytes 0 No valid adjacency
Routing failed to locate next hop for TCP from inside:192.168.112.x/x to fw-mgmt:192.168.115.x/x
I've tried adding a static route on firewall:
route fw-mgmt  192.168.115.0 255.255.255.0 192.168.112.1
ERROR: Cannot add route, connected route exists
Any ideas what this could be?
5 REPLIES 5
VIP Mentor
Re: ASA 8.4 no connection one interface to another
Do you have an interface in the 192.168.115.0 network? Please post the output of
asa# sh int ip brie
And which systems are communicating? What are there Locations (interfaces) and IP-addresses?
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Beginner
I have a server in the 115 subnet 192.168.115.100 and requires communication to 192.168.112.100 in 112 subnet
Ethernet0/1                unassigned
Ethernet0/1.112            192.168.112.x    inside  100
Ethernet0/1.118            192.168.118.x   fw-mgmt  80
Ethernet0/2                192.168.115.x  dmz  50
Ethernet0/3                192.168.64.x    inner-mgmt 100
Management0/0              1.1.1.1
VIP Mentor
So you have a communication from dmz to inside?
Paste your NAT- config and the ACL on the dmz-interface.
And what is the output of packet-tracer:
packet-tracer input dmz 192.168.115.100 1234 192.168.112.100 PORT-YOU-WANT-TO-USE
Beginner
Sorry the IP add is 115.91 and 112.54
access-list DMZ_IN extended permit tcp 192.168.115.0 255.255.255.0 host 192.168.115.251 object-group srv_WebPorts
access-list DMZ_IN extended permit object-group srv_VMwareIn object-group DMZ_VirtualHosts object vCentre
access-list DMZ_IN extended permit ip object-group DMZ_VirtualHosts object vCentre
access-list DMZ_IN extended permit udp 192.168.115.0 255.255.255.0 host 192.168.112.100 eq ntp
access-list DMZ_IN extended permit tcp host 192.168.115.91 host 192.168.112.54 eq 5723
access-list DMZ_IN extended permit tcp host 192.168.112.54 host 192.168.115.91 eq 5723
access-list DMZ_IN extended deny ip any any log
object network inside_NAT
subnet 192.168.112.0 255.255.255.0
object network vCentre
host 192.168.112.206
object network vCentre-DMZ_NAT
host 192.168.115.253
object network SECISM
object network SECISM-DMZ_NAT
host 192.168.115.252
nat (inside,outside) source static inside_NAT inside_NAT
nat (inside,dmz) source static vCentre vCentre-DMZ_NAT
nat (inside,dmz) source static SECISM SECISM-DMZ_NAT
nat (inside,outside) source dynamic inside_NAT interface
nat (inside,dmz) static 192.168.115.253 dns
object network SECMGMT01
nat (inside,dmz) static 192.168.115.252
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.112.0   255.255.255.0   inside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group DMZ_IN in interface dmz
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 7901509, packet dispatched to next module
Result:
input-interface: dmz
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
VIP Mentor
Your ASA says that the traffic should work. What config do you have regarding interface "fw-mgmt"?
And test again and show the corresponding log.
Content for Community-Ad
FusionCharts will render here
