ASA 8.4 - Static NAT - Problem with outbound SMTP-new***
telematic_2
Hi everyone!
We have seen an old thread about this problem that says:
The issue here is with the order of NAT rules in the 8.4 version.
A Manual NAT rule takes precedence over Auto NAT (within object group).
So, nat (inside,outside) source dynamic any interface; is taking precedence when going from inside to outside.
Our situation is the same ASA 8.4(2), we can't send email with the wan mail server address.
How can we solve this problem??
See the attached txt file for our NAT configuration for the internal mail server (lan ip 10.240.2.32, wan 88.x.x.x).
mikull.kiznozki
add rules to your inside access out as well..
abinjola
In Section 2 table (NAT order of operation), static takes precedence over dynamic NAT,
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/nat_overview.html#wp1118157
Add a static for your email server
The following example configures static NAT for the real host 10.1.1.1  on the inside to 2.2.2.2 on the outside using a mapped object.
hostname(config)# object network my-mapped-obj
hostname(config-network-object)# host 10.2.2.2
hostname(config-network-object)# object network my-host-obj1
hostname(config-network-object)# host 10.1.1.1
hostname(config-network-object)# nat (inside,outside) static my-mapped-obj
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/nat_objects.html#wp1106703
gouravbathla
You may check with this single NAT statement (instead of port-forwarding) since ports can be managed by applied ACL.
object network hst-10.240.2.32
host 10.240.2.32
description mailserver Host Object
nat (inside,outside) static 88.x.x.x
Note:-But remove earlier configured NAT statements before using this.
thanks to everyone!
