Welcome to Cisco Firewalls Community
164
Beginner
ASA 8.6 vpn clients hairpin to remote l2l sida no work?
I just replaced a pair of older ASA firewalls running 8.3 with 5515-X running 8.6. One part is not working and I'm not sure if there has been any changes that prevents it or I overlook an detail.
Our vpn clients connecting to our office firewalls can reach our internal networks and internet (no split tunnel, everything is tunneled). They can't however reach any remote L2L networks.
1) I see hitcnt for outside_access_in
2) I don't see NAT hits (masq vpn clients to a specific nat ip when bound for customer X networks)
Basic config
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network ipsecvpnpool
 subnet 172.16.32.0 255.255.255.0
object network customer-dmz
 subnet 10.10.74.0 255.255.255.0
access-list outside_access_in line 1 extended permit ip object ipsecvpnpool object customer-dmz (hitcnt=0) 0xabe3ed7e
  access-list outside_access_in line 1 extended permit ip 172.16.32.0 255.255.255.0 10.10.74.0 255.255.255.0 (hitcnt=197) 0xabe3ed7e
access-list outside_access_out line 1 extended permit ip any object customer-dmz (hitcnt=0) 0xa0406a63
  access-list outside_access_out line 1 extended permit ip any 10.10.74.0 255.255.255.0 (hitcnt=0) 0xa0406a63
Rule 6 with no hits, clearly not affected by any other rules:
1 (dmz) to (outside) source static ns2 other-nat-1   destination static other_cust_1 other_cust_1
    translate_hits = 12, untranslate_hits = 0
2 (outside) to (outside) source static ipsecvpnpool other-nat-2   destination static other_cust_2 other_cust_2
    translate_hits = 0, untranslate_hits = 0
3 (outside) to (outside) source static ipsecvpnpool other-nat-3  destination static other_cust_3 other_cust_3
    translate_hits = 0, untranslate_hits = 259
4 (outside) to (outside) source dynamic ipsecvpnpool other-nat-4   destination static other_cust_4 other_cust_4
5 (outside) to (outside) source static ipsecvpnpool other-nat-5  destination static other_cust_5 other_cust_5
6 (outside) to (outside) source dynamic ipsecvpnpool customer-nat-ip   destination static customer-dmz customer-dmz
A capture on 'ip any object customer-dmz' on interface outside shows nothing, thus its not trying without the NAT. Something has got to be blocking this.
5 REPLIES 5
Beginner
I do see "routing failed to
I do see "routing failed to locate next hop for outside" using debug logging.
Rising star
Hi there,  I understand that
Hi there,
I understand that you have below objected defined.
Tell me, do you have separate tunnel terminates to customer's-DMZ segment?
If I understood you right, you want your remote-vpn-client to access remote customer's-DMZ segment?
Please post yours answers, along with your current configs.
thanks
Beginner
Hi, Yes I have. I have
Yes I have. I have narrowed the problem down to generic nat rules that inflict albeit coming later in the chain:
Something like this makes it fail:
<snip>
55 (lan) to (outside) source dynamic any any destination static rfc1918 rfc1918
This actually makes ipsecvpnpool haripinning towards external L2L tunnel fail. I simply can't have generic catch all (no)nat rules.
I have hired a consultant to come and explain the issues, I will report back once I know exactly what is happening.
Rising star
Hi there, You might want to
Hi there,
You might want to read this thread below, and this will help resolve your issue.
https://supportforums.cisco.com/discussion/12424821/can-not-ping-between-remote-vpn-site
thanks
Rizwan Rafeek
Beginner
Rizwan: That's a negative, it
Rizwan: That's a negative, it won't resolve my issue as I'm already doing this (see part in bold):
Content for Community-Ad
FusionCharts will render here
