04-07-2018 03:59 AM - edited 02-21-2020 07:36 AM
Hi Experts
BFD feature is not working on ASA 9.9 running on FPR9300 chassis. Is it supported at all? While debugging, there is no traffic sent to peer device (SRX340).
Any advice?
Cheers.
Sumanta .
Solved! Go to Solution.
07-03-2018 08:02 AM
Documentation says it is not.
Supported in routed firewall mode; support for standalone, failover, and cluster modes. BFD is not supported on failover and cluster interfaces. In clustering this feature is only supported on the primary unit. BFD is not supported in transparent mode.
07-03-2018 08:02 AM
