Welcome to Cisco Firewalls Community
634
Beginner
ASA Blocking
I have installed ASA 5510 to limit sessions of Users to 170. But as soon as i put it infront of network before router, Internet goes down and i cannot browse or something.
The network is simple, Cisco three layer model with users on Wired LAN/Wireless LAN using WLC. Approx 2500-3000 users.
Can you please guide me what i am doing wrong in Config or how to start troubleshooting?
Running Config is pasted below.
Thanks in Advance.
Bilal
GV-ASA5510-INSIDE# show run
: Saved
ASA Version 9.1(1)
firewall transparent
hostname GV-ASA5510-INSIDE
names
dns-guard
interface Ethernet0/0
duplex full
nameif outside
bridge-group 1
security-level 100
interface Ethernet0/1
duplex full
nameif inside
bridge-group 1
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
interface Ethernet0/3
shutdown
no nameif
no security-level
interface Management0/0
management-only
shutdown
no nameif
no security-level
ip address 192.168.1.2 255.255.255.0
interface BVI1
ip address 172.16.1.4 255.255.255.0
time-range 02/11/2011+7
absolute end 22:22 09 November 2011
time-range 03-11-11
absolute end 17:00 09 November 2011
periodic daily 0:00 to 23:59
time-range 09-11-11
absolute end 16:33 16 November 2011
time-range 13/11/2011+7
time-range 19/11/2011+7
absolute end 20:49 26 November 2011
time-range 3.161
absolute end 16:35 10 February 2011
ftp mode passive
clock timezone AFT 4 30
dns server-group DefaultDNS
domain-name GreenVillage
same-security-traffic permit inter-interface
object network 10.100.5.52
host 10.100.5.52
object network 203.88.70.113
host 203.88.70.113
object network 203.88.70.117
host 203.88.70.113
object network Blackberry_Steven
host 10.100.2.245
description BB
object network 172.16.10.155
host 172.16.10.155
description Blocked user on 09/11/2011
object network 172.16.30.141
host 172.16.30.104
object network 172.16.20.247
host 172.16.20.247
object network 172.16.40.125
host 172.16.40.125
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list 100 extended permit ip any any log
access-list HighBandUsers extended deny ip any host 66.77.197.61
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit ip any any
access-list LAN_subnets extended permit ip 10.0.0.0 255.0.0.0 any inactive
access-list LAN_subnets extended permit ip 172.16.0.0 255.255.0.0 any inactive
access-list LAN_subnets extended permit ip 192.168.0.0 255.255.0.0 any inactive
access-list LAN_subnets extended permit ip any 10.0.0.0 255.0.0.0 inactive
access-list LAN_subnets extended permit ip any 172.16.0.0 255.255.0.0 inactive
access-list LAN_subnets extended permit ip any 192.168.0.0 255.255.0.0 inactive
access-list All_Incoming extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route inside 0.0.0.0 0.0.0.0 172.16.1.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication telnet console LOCAL
aaa authentication enable console LOCAL
aaa authorization command LOCAL
aaa authorization exec LOCAL
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh version 2
console timeout 0
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 20 burst-rate 5300 average-rate 2900
dynamic-filter use-database
dynamic-filter enable
dynamic-filter enable interface outside
dynamic-filter enable interface inside
dynamic-filter drop blacklist interface inside action-classify-list LAN_subnets
dynamic-filter ambiguous-is-black
username gvadmin password xTTON9V41CE0Cr6l encrypted privilege 15
username admin password 5CzeSC0cUSYc3HMs encrypted privilege 15
class-map CONNS_LIMIT
match access-list LAN_subnets
class-map CONNS_Limit
class-map CONNS
class-map inspection_default
match default-inspection-traffic
class-map Limit_Incoming_Class
match access-list All_Incoming
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map CONN_Limit
description //User Connection Limit\\
class CONNS_LIMIT
  set connection per-client-max 175 per-client-embryonic-max 100 random-sequence-number disable
policy-map TRAFFIC_LIMITING
class Limit_Incoming_Class
policy-map PM-POLICE-WEB
class CONNS_Limit
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
service-policy CONN_Limit interface inside
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
hpm topN enable
Cryptochecksum:f74fa843bfc7bb2f94e5d6ef889d21a4
: end
Everyone's tags (2)
5 REPLIES 5
Participant
ASA Blocking
The security level on the outside interface is 100 and should be 0.
Also, I dont see nat configured but maybe it is not needed.
Felipe.
Beginner
Re: ASA Blocking
Normally, interfaces on the same security level cannot communicate. So please change your outside leg security level to 0 and try to access internet or you can below feature of ASA with same security level.
same-security-traffic:
To permit communication between interfaces with equal security levels, or to allow traffic to enter and exit the same interface, use the same-security-traffic command in global configuration mode. To disable the same-security traffic, use the no form of this command.
Syntax:
same-security-traffic permit {inter-interface | intra-interface}
no same-security-traffic permit {inter-interface | intra-interface}
Note:
This command is disabled by default.
show running-config same-security-traffic - Displays the same-security-traffic configuration.
Jermy Franklin A
Beginner
ASA Blocking
Thanks for guidance. Now its working good.
One more question, i have limited all users to max 170 sessions/client plus 100 embroynic connections. And its dropping sessions above that. How can i find that which sessions are dropped for any particular user or as whole?
Also Peer-to-Peer(torrents) are consuming lot of sessions. As soon as any user open P2P, his http and other tcp connections dropped. how to check that dropped connections?
And how to block these torrent ports?
Please guide.
Bilal
Beginner
ASA Blocking
Is there any way we can put cap on per user anywhere in router, firwall or WLC?
Becuase from shared pipe, when one user sucks the bandwidth others have to say suffer.
Please guide where should i limit that per user.
Bilal
Participant
ASA Blocking
I would suggest creating a new discussion for every new issue.
Also make sure to mark the initial issue as answered so others can learn from this.
Felipe.
