Welcome to Cisco Firewalls Community
287
ASA double NAT
Hello,  I have my double nat config as below on an ASA.
object-group network inside-host
 network-object host 10.10.105.41
object network 1st-nat
 host 6.0.10.49
object network 2nd-nat
 host 206.125.46.2
nat (inside,outside) source static inside-host 1st-nat destination static 2nd-nat 2nd-nat
My question is - Can I add a new host 10.10.105.42 inside the 'inside-host' object group? How will react when it comes to natting with 1st-nat and 2nd-nat?
Thanks.
2 REPLIES 2
Participant
If you will do it, it will
If you will do it, it will allow without any error. However it is a static NAT statement, so that both source IP should have different mapped address. Otherwise traffic coming to  6.0.10.49 will redirect to 10.10.105.41 but not 10.10.105.42
Thank you.
Thank you.
