Welcome to Cisco Firewalls Community
224
Beginner
ASA (from LAN network to ASA outside interface ping )
R1
int G0/0  IP Add 192.168.1.1/24
ASA
Int G0/1 IP Add 192.168.1.10/24
Int G0/0 IP Add 210.19.10.10/24
R2
Int G0/0 IP Add 210.19.10.1/24
___________________________________________
If i ping fro R1 int g0/0 to  ASA g0/1 its working
R1# ping 192.168.1.10
*but i cant ping  from R1 int G0/0 to  ASA int G0/0
R1# ping 210.19.10.10 ??????????????????
*  please tell me reason ?
4 REPLIES 4
Advisor
It's a security feature of the ASA.
Beginner
Hi Lalit,
It's right it's the security feature of ASA in which user at one end is not able to ping far end interface of the ASA, you could ping across the ASA but not the ip of ASA's far end interface.
- Prateek Verma
Beginner
Thanks Prateek
  i want know according  to packet flow of firewall, when  we ping that interface  where this packet is drop.
Beginner
Hi Lalit,
It's the default security feature of ASA due to which it is not allowed to ping far end interface ip of ASA. If you will try to run packet-tracer on ASA , you will see everything is allowed but it would get dropped in slow path secuirty check failed ( that's due to the default security feature of ASA).
- Prateek Verma
Content for Community-Ad
FusionCharts will render here
