09-10-2019 12:05 PM - edited 02-21-2020 09:28 AM
the request is when the traffic hit the public IP on port 222, i need to redirect to a internal server on port 22.
mu configuration is like this:
object network FTP-Access
nat (dmz2,outside) static FTP-SVR-Public service tcp ssh 222
access-list global_access extended permit tcp any object FTP-Access eq 222
access-group global_access global
but it doesn't work.
please help.
thanks
09-10-2019 12:13 PM
09-10-2019 12:21 PM
i tried both the ports in ACL, but didn't work, even no traffic hit the rule.
09-10-2019 12:25 PM
09-10-2019 12:46 PM
the static nat is above the dynamic nat, we using different public IP for different port forwarding, and the PAT still go through the main public IP.
nat (dmz2,outside) after-auto source dynamic any interface
09-10-2019 12:51 PM
09-10-2019 01:01 PM
the configuration has been changed , because we decided to use the same port 22 and it works fine.
thanks for you help.
i will set up a lab to do more tests for this issue.
thanks
