ASA Show Blocks
doylepaul
Hi, I have been researching a little about ASA memory because of what I could see below. The fourth row down suggests a high count of over four thousand million! I thought the max would be 5684? I started looking here because my Free Memory was at 4% (below). Not sure how long it has been like this to be honest?
Any ideas or input greatly welcome :-)
I see exactly the same value in the High column for a size value of 256 across several contexts but not all contexts?
------------------ show blocks ------------------
  SIZE    MAX    LOW    CNT  INUSE   HIGH
     0   1450   1430   1450      0      0
     4    100     99     99      0      0
    80   1000    934   1000      0     13
   256   5684   4981   5679      4 429496729
  1550   6289   5695   6260     26     54
  2048   7100   6651   7100      0      0
  2560    164    163    164      0      0
  4096    100     99    100      0      0
  8192    100    100    100      0      0
  9344    100    100    100      0      0
 16384    102    102    102      0      0
------------------ show interface ------------------
------------------ show memory ------------------
Free memory:         185907632 bytes ( 4%)
Used memory:        4109059664 bytes (96%)
Total memory:       4294967296 bytes (100%)
Many thanks again.
Maykol Rojas
Hello;
This is a good place to look in case there are performance issue, most problems related to high memory utilization (90% of the times) do not have to do with memory blocks.
When you see the memory this high, it can be due to a couple of factors:
1-Device oversubscription
2-Memory issue due to a process not freeing memory (possibly a bug)
The fact that you see block 256 this high can be normal if you have intensive logging and/or failover with HTTP replication.
From this point forward you can do the following:
Check if http replication is enable (disable it)
Check the configuration for threat detection (it would be best if it has its defaults)
Check the amount of ACLs configured (try rebooting the device, if after the reboot the memory continues hight), you can check the amount of entries by doing "show access-list | inc elements"
Last, if none of them show the issue, contact Cisco TAC with the output of "show memory detail".
If you have any questions, let me know.
Mike.
Mike
Maykol Rojas
Hello;
Mike.
Mike
Thanks Mike I really appreciate your response!
I promise this is the last question ;-) But I also noticed (below) that only one of the RX rings and one of the TX rings appears to be being used! I would have thought that the ASA would load balance the RX and TX rings, unless of course one specific device is sending a massive amount of data? Does this sound right?
I am not on site now so can't investigate any further but will check out your suggestions when I return to site.
Many thanks again :-)
Interface Internal-Data0/1 "", is up, line protocol is up
  Hardware is ivshmem rev03, BW 1000 Mbps, DLY 10 usec
(Auto-duplex), (1000 Mbps)
Input flow control is unsupported, output flow control is unsupported
MAC address 0000.0001.0002, MTU not set
IP address unassigned
548911 packets input, 42815058 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
548911 packets output, 42815058 bytes, 0 underruns
0 pause output, 0 resume output
0 late collisions, 0 deferred
0 output decode drops
0 input reset drops, 0 output reset drops
Queue Stats:
 RX[00]: 548911 packets, 42815058 bytes, 0 overrun
         Blocks free curr/low: 2687/2677
 RX[01]: 0 packets, 0 bytes, 0 overrun
         Blocks free curr/low: 2687/2687
 RX[02]: 0 packets, 0 bytes, 0 overrun
 TX[00]: 548911 packets, 42815058 bytes, 0 underruns
         Blocks free curr/low: 2687/2545
 TX[01]: 0 packets, 0 bytes, 0 underruns
 TX[02]: 0 packets, 0 bytes, 0 underruns
  Control Point Interface States:
Interface number is 11
Interface config status is active
Interface state is active
Excellent question.
Is this an ASA 5550?
Mike.
Mike
Hi Mike, haha yes its a 5525 with 4Gb of ram! How did you know that?
