ASA split tunnel
Pawan Raut
Level 4
Level 4
Hi I want to do split tunnel in anyconnect vpn. All traffic should go via tunnel except zoom meeting and it should go via local internet
Afolarin Omole
@Pawan Raut
I think you are doint the same traditional split tunelling where RA users can access corporate network and internet. This involves the below stage ,
  • defining your ACL
  • associating the ACL with tunnel group policy
Please remember the ACL should specify the traffic to be protected . Please follow this link :
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/70847-local-lan-pix-asa.html#anc8
NOTE : you can either excludespecified or tunnelspecified
Please rank this post .
mkazam001
Level 3
Level 3
Here is the config:
This will encrypt traffic & send over vpn to that destinsation, everything else will be routed locally.
In your scenario, you could try try permit any over the tunnel & deny the zoom meeting IP addresses - not sure if that would work but might be worth a try.
Regards, mk
access-list split-tunnel standard permit 192.168.1.0 255.255.255.0
group-policy TELECOMM attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split-tunnel
