Welcome to Cisco Firewalls Community
202
ASA two crypto tunnels with two ISPs
I have a quick question.
Is it must to create two transformer sets for each crypto-map policies? or can I use already configured and being used in first crypto map transformer set to second crypto map policy? I have typed an example below.
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto map Outside-ATT1-crypto-map 1 match address ACL-1
crypto map Outside-ATT1-crypto-map 1 set peer 10.10.10.1
crypto map Outside-ATT1-crypto-map 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map Outside-ATT1-crypto-map 1 set security-association lifetime seconds 28800
crypto ikev1 enable outside-ATT1
crypto map Outside-ATT-crypto-map interface outside-ATT1
crypto map Outside-ATT2-crypto-map 1 match address ACL-2
crypto map Outside-ATT2-crypto-map 1 set peer 10.10.10.2
crypto map Outside-ATT2-crypto-map 1 set ikev1 transform-set ESP-AES-256-SHA
crypto map Outside-ATT2-crypto-map 1 set security-association lifetime seconds 28800
crypto ikev1 enable outside-ATT2
crypto map Outside-ATT-crypto-map interface outside-ATT2
Thank you in advanced.
Anthonize
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Anthonize,
Hi Anthonize,
You can use same transform set multiple times in different crypto map sequence.
Dinesh Moudgil
P.S. Please rate helpful posts.
2 REPLIES 2
Hi Anthonize,
Hi Anthonize,
Dinesh Moudgil
Thanks Dinesh.
Thanks Dinesh.
