Welcome to Cisco Firewalls Community
222
Beginner
ASA5500X Port Scan
ello Everyone,
We have a plain ASA (no ids/ips, firepower), we want to determine if the device is being port scanned. Did some quick scan (nmap) and all i see by filtering the device that im scanning it from is this
%ASA-4-313009: Denied invalid ICMP code 9, for outside:scanner.ip.address/6523 (scanner.ip.address/6523) to identity:asa.outside.ip/0 (asa.outside.ip/0), ICMP id 295, ICMP type 8
There were no significant increase in the logs, no spikes in count, sessions and health (movement) as well.
What event/s or logs messages should we watch out for if the device if being scanned?
Thanks in advance
Everyone's tags (3)
2 REPLIES 2
Collaborator
Re: ASA5500X Port Scan
You might need to enable a few things to detect scans.
  1. you can enable access-list logging for the deny at the end of the outside access-list
  2. you can enable "threat-detection scanning-threat"
You can then look at the "Denied" and "Scanning" messages in the log
John
**Please rate posts you find helpful**
VIP Advisor
Device scans won't impact ASAs as they aren't targeted for interruption.
DoS attack is what cause interruption.
Port scans are captured on connection built and deny connection logs. What
differentiates them is the sequence and the pattern which you either need
to understand to recognize that or use an intelligent tool which can pick
it
