ASA5505 Port Forward/Translation
mtehonica
Level 5
Level 5
I'm trying to configure static PAT for a Linux SSH server on my network.  The tricky part is that I'm trying to map port 21 from the outside to port 22 on the inside (because port 22 is blocked on my work network).
I've tried the following but it doesn't seem to be working.  I'm running ASA software version 9.1(4)
object network LinuxAdmin
host 192.168.1.108
object service tcp21
service tcp source eq ftp
object service tcp22
service tcp source eq ssh
nat (inside,outside) source static LinuxAdmin interface service tcp21 tcp22
access-list outside_in extended permit tcp any object LinuxAdmin eq ftp
access-group outside_in in interface outside
I thought this should work but it's not.... when I do a show access-list, I don't see any hits against that rule.  Any help or suggestions would be appreciated.
Matt
2 Accepted Solutions
Jouni Forss
To my understanding on the "service" section of the command the REAL service comes first and then the MAPPED service. So you could try switching the "tcp21" and "tcp22" the other way around.
Naturally you will also have to change the "access-list" to allow the port TCP/22 rather than TCP/21
I am not sure but the traffic might also match the FTP Inspection also so you might want to come up with another MAPPED port for this connection, like TCP/222
Hope this helps
- Jouni
I think your NAT statement is a little off.  Try the following
object network obj-192.168.1.108
   host 192.168.1.108
   nat (inside,outside) static interface service tcp 22 21
access-list outside_in extended permit tcp any object LinuxAdmin eq 22
Please remember to rate and select a correct answer
Please remember to select a correct answer and rate helpful posts
Jouni Forss
Hope this helps
- Jouni
   host 192.168.1.108
mtehonica
Level 5
Level 5
Thanks guys, that fixed it!  Didn't realize it was then .
