12-24-2018 01:09 AM - edited 02-21-2020 08:36 AM
Dear Experts,
Kindly i have an ASA5506 for my client and it stop working,
i try to enter via Console but i doesn't give me anything, only a blank page
the power LED is Green
the Status LED is Blinking Red
the Active LED is OFF
the MGMT Port LED is Green
The Interface 1 and 2 OFF when connect the cables ( outside-inside)
i try to reboot it many time but nothing happen
any Advice for it
Solved! Go to Solution.
12-26-2018 02:52 AM
12-24-2018 01:28 AM
if this is the case it could be brick. best do RMA if you have cisco service contract in place.
and also its a 5506-x could be it had a clocking issue. worth to check this link
https://www.cisco.com/c/en/us/support/docs/field-notices/642/fn64228.html
12-24-2018 03:16 AM
Well note
ASA5506-K8 All revisions and all prior versions are affected
Product ID Possibly Affected VID Fixed VID
ASA5506 V03 or earlier V04 or later
The security appliances no longer function and, subsequently, the system fails to boot.
In addition, the LED status indicators on the security appliance illuminate as follows:
Power LED is green
Status LED is amber and blinking
My Item is ASA5506-K8 V02 , So possibly affected by the issue
Best solution to do, is to open a case on the Smartnet and RMA the Item ?
12-26-2018 02:46 AM
Kindly, the Defected ASA5506-X has an L-ASA5506-SEC-PL= License
and the token dedicated to the ASA5506-X thought the Serial number
when the defected ASA replaced to a new one, it will have an Different Serial Number
how to add the the L-ASA5506-SEC-PL= in the Replaced one ?
do i need to open a Case to make the Pak dedicated to the New Replaced ASA Serial Number ???
12-26-2018 02:52 AM
12-24-2018 08:30 AM
03-24-2020 04:52 PM
Hi guys,
is there any chance to unbrick the ASA5506-X with same issue - no booting, leds etc - but we don't have service contract... ?
Thank you for any advice.
Lukas
08-11-2020 07:01 AM
you have to open the case and switch between the two RAM slots.
salah Gobaa
09-17-2020 02:16 AM
Hi, I bought the used ASA5506-x from Ebays.
I took the below steps to reset the device to the factory default:
pressed the ESC key to interrupt boot.
rommon #0> confreg 0x41
rommon 1> boot
after that, I was able to add the new adm-user and password
change the host-name to ASA
reload
After the ASA enters the first boot, I press the ESC key again but this time, I noticed
the Status LED is Blinking Amber
And getting an error see the screenshot attached.
The device PID VID: ASA5506-K9 V06
Could you please help?
