ASA5510 and RDP
todd
Hello all,
Recently implemented an ASA5510 and as a total noob on this device I cannot setup RDP access. I've browsed these and other forums and tried all the suggestions that I've been able to find and still no luck. Any help from those of you with more experience would greatly be appreciated.
Below is my running config. I have a spare external static ip that i can use 24.xx.xx.57, but would prefer to use the IP of the outside1 interface 24.xx.xx.53. I need access to 3 different machines and was thinking of using ports 3388, 3389 and 3390.
Thanks!!
Result of the command: "show running-config"
: Saved
ASA Version 8.2(1)
hostname ASA5510
enable password xxx encrypted
passwd xxx encrypted
names
interface Ethernet0/0
nameif outside1
security-level 0
ip address 24.xx.xx.53 255.255.255.240
interface Ethernet0/1
speed 100
duplex full
nameif outside2
security-level 100
ip address 172.xx.xx.1 255.255.255.240
interface Ethernet0/2
nameif inside1
security-level 100
ip address 192.168.30.10 255.255.255.0
interface Ethernet0/3
speed 100
duplex full
nameif inside2
security-level 100
ip address 192.168.40.2 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network LV_SERVERS
network-object host 8.xx.xx.30
network-object host 8.xx.xx.32
network-object host 8.xx.xx.33
network-object host 8.xx.xx.37
network-object host 8.xx.xx.39
object-group network SQPEZZ_NETWORK
network-object 192.168.40.0 255.255.255.0
access-list inside2_access_out extended permit ip any any
access-list inside2_access_out extended permit icmp any any
access-list inside2_access_out extended permit tcp any any
access-list outside1_access_out extended permit ip any any
access-list inside2_access_in extended permit ip any any
access-list inside2_access_in extended permit icmp any any
access-list inside2_access_in extended permit tcp any any
access-list inside1_access_in extended permit ip any any
access-list inside1_access_in extended permit icmp any any
access-list inside1_access_in extended permit tcp any any
access-list outside2_access_in extended permit ip any any
access-list inside1_access_out extended permit ip any any
access-list inside1_access_out extended permit icmp any any
access-list inside1_access_out extended permit tcp any any
access-list VPN-TO-LV extended permit ip object-group SQPEZZ_NETWORK object-group LV_SERVERS
access-list IPSEC-TO-LV extended permit ip host 24.xx.xx.56 object-group LV_SERVERS
pager lines 24
logging enable
logging asdm informational
mtu management 1500
mtu inside1 1500
mtu inside2 1500
mtu outside2 1500
mtu outside1 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside2) 1 interface
global (outside1) 1 interface
global (outside1) 2 24.xx.xx.56
nat (inside1) 1 192.168.30.0 255.255.255.0
nat (inside2) 2 access-list VPN-TO-LV
nat (inside2) 1 192.168.40.0 255.255.255.0
static (inside1,inside2) 192.168.30.0 192.168.30.0 netmask 255.255.255.0
static (inside2,inside1) 192.168.40.0 192.168.40.0 netmask 255.255.255.0
access-group inside1_access_in in interface inside1
access-group inside1_access_out out interface inside1
access-group inside2_access_in in interface inside2
access-group inside2_access_out out interface inside2
access-group outside2_access_in in interface outside2
access-group outside1_access_out out interface outside1
route outside1 0.0.0.0 0.0.0.0 24.xx.xx.49 1
route outside2 10.xx.xx.0 255.255.255.0 172.xx.xx.2 1
route outside2 172.xx.xx.0 255.255.255.0 172.xx.xx.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.30.0 255.255.255.0 inside1
http 192.168.40.0 255.255.255.0 inside2
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map VPN_MAP 1 match address IPSEC-TO-LV
crypto map VPN_MAP 1 set peer 4.xx.xx.48
crypto map VPN_MAP 1 set transform-set ESP-AES-256-SHA
crypto map VPN_MAP 1 set security-association lifetime seconds 86400
crypto map VPN_MAP 1 set security-association lifetime kilobytes 10000
crypto map VPN_MAP interface outside1
crypto isakmp enable outside1
crypto isakmp policy 5
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
telnet 192.168.40.0 255.255.255.0 inside2
telnet timeout 5
ssh 192.168.40.0 255.255.255.0 inside2
ssh timeout 5
ssh version 2
console timeout 0
dhcpd address 192.168.1.2-192.168.1.5 management
dhcpd enable management
dhcpd address 192.168.30.30-192.168.30.120 inside1
dhcpd dns 10.xx.xx.170 10.xx.xx.170 interface inside1
dhcpd enable inside1
dhcpd address 192.168.40.15-192.168.40.100 inside2
dhcpd dns 10.xx.xx.170 10.xx.xx.170 interface inside2
dhcpd enable inside2
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username xxx password xxx encrypted privilege 15
tunnel-group 4.xx.xx.48 type ipsec-l2l
tunnel-group 4.xx.xx.48 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
2 Accepted Solutions
Ohh,
But that 20.1.1.10 is the host on the internet that is trying to access your RDP server, it is just an access list to restrict the guys who are going to access your RDP server, for example here,
This is the access list, this says that only host 20.1.1.10 on the internet will be able to talk to the RDP server on the RDP server port
access-list outside_access_in extended permit tcp host 20.1.1.10 host 209.165.200.10 eq 3389
This is the NAT so the outside users can reach the server
static (inside,outside) 209.165.200.10 172.16.11.10 netmask 255.255.255.255
And this is the access list applied to the interface where the packet is coming from
access-group outside_access_in in interface outside
If you have nay further questions let me know.
Mike
Mike
You need to apply the access-group
access-group outside1_access_in in interface outside1
Mike
Mike
13 Replies 13
Mike,
I've reviewed that documentation, but can't make heads or tails of it.
I understand the 20.1.1.10 external ip address and the 172.16.11.10 internal ip but I get lost with the 209.165.200.10
I have only an external ip address 24.xx.xx.53 and a couple internal ip's 192.168.30.xx's
I'd appreciate any clarification that you might be able to offer.
Thanks.
I've added the following to the config, but it still doesn't work.
object-group service RDP tcp
port-object eq 3389
access-list outside1_access_in extended permit tcp any any object-group RDP
static (inside1,outside1) tcp interface 3389 192.168.30.210 3389 netmask 255.255.255.255
Mike
Mike
Ohh,
Mike
Mike
Mike,
So I have now applied the following:
port-object eq 3389
and clear xlate but still no success.
Ok,
Try this,
packet-tracer input outside1 tcp 4.2.2.2 1025 24.x.x.53 3389
Change the x for the outside1 IP... That would simulate a packet coming through the ASA with port 3389. I want to check if the firewall would allow it or deny it.
Mike
Mike
Results:
Result of the command: "packet-tracer input outside1 tcp 4.2.2.2 1025 24.x.x.53 3389"
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
  match tcp inside1 host 192.168.30.210 eq 3389 outside1 any
    static translation to 24.x.x.53/3389
    translate_hits = 0, untranslate_hits = 3
NAT divert to egress interface inside1
Untranslate 24.x.x.53/3389 to 192.168.30.210/3389 using netmask 255.255.255.255
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
port-object eq 3389
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 7
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 9
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
  match ip inside1 192.168.30.0 255.255.255.0 inside2 any
    static translation to 192.168.30.0
    translate_hits = 1869, untranslate_hits = 9376
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 5408732, packet dispatched to next module
Result:
input-interface: outside1
input-status: up
input-line-status: up
output-interface: inside1
output-status: up
output-line-status: up
Action: allow
Certainly seems like is not the ASA which is dropping them
Do you have time for some capturing? I'll be online for a couple of hours so I can check them....
do the following:
capture out interface outside1 match tcp any any eq 3389
capture in interface inside1 match tcp any any eq 3389
Try to connect via RDP, once it fails, go ahead and do the following:
show cap out
show cap in
Copy the output and paste it here, feel free to mask the IPs.
Mike...
Mike
Result of the command: "show cap out"
0 packet captured
0 packet shown
Result of the command: "show cap in"
9 packets captured
   1: 19:04:55.283341 192.168.30.200.3389 > 192.168.40.5.64885: P 2811343421:2811343538(117) ack 3776020312 win 258
   2: 19:04:55.490529 192.168.40.5.64885 > 192.168.30.200.3389: . ack 2811343538 win 253
   3: 19:05:06.450660 192.168.30.200.3389 > 192.168.40.5.64885: P 2811343538:2811343591(53) ack 3776020312 win 258
   4: 19:05:06.650006 192.168.40.5.64885 > 192.168.30.200.3389: . ack 2811343591 win 253
   5: 19:05:09.872910 192.168.40.5.64885 > 192.168.30.200.3389: P 3776020312:3776020365(53) ack 2811343591 win 253
   6: 19:05:09.873917 192.168.30.200.3389 > 192.168.40.5.64885: P 2811343591:2811343660(69) ack 3776020365 win 258
   7: 19:05:10.079005 192.168.40.5.64885 > 192.168.30.200.3389: . ack 2811343660 win 253
   8: 19:05:26.468527 192.168.30.200.3389 > 192.168.40.5.64885: P 2811343660:2811343713(53) ack 3776020365 win 258
   9: 19:05:26.670497 192.168.40.5.64885 > 192.168.30.200.3389: . ack 2811343713 win 258
9 packets shown
Not sure what's up with the 192.168.30.200 since I configured for 192.168.30.210
I dont see the packets arriving to the outside interface... when you do the RDP you are doing it to the 24 not the 192 address right?
Mike
Mike
Yes I was, but I was trying to log in from an internal machine with the external IP address.
Once I tried from an off network machine it worked correctly and I was able to quickly configure the natting for a couple additional external ports and internal ip's
Apparently using the external ip address from an internal machine requires additional configurations that we don't really need to explore since it's not a necessary function.
I appreciate all your help with this!!
Exactly, if you try to access the RDP from inside using the public IP, it will actually give you an error, that is what is called U-Turning or Hairpinning which as you suggested requires additional configuration.
If you want to configure that in the future just come back to this forum, I will help you out with that.
For now I think that it would be it.
Glad it worked.
Mike
Mike
