12-22-2012 07:42 AM - edited 03-11-2019 05:40 PM
Currently my ASA5510 has a 64MB internal flash. Does the ASA require a higher capacity flash for an IOS upgrade from 7.2(x) to 8.2(x)? The Cisco Release Notes does not state any internal flash requirement, but just wanted to double check.
Solved! Go to Solution.
12-22-2012 09:22 AM
It seems to me that the 8.2(5) takes around 15MB of space. ASA 7.2(5) is around 8MB if I'm not mistaken. ASDM for 7.2 IOS seems to be around 6MB. So I would imagine that the IOS/ASDM images alone atleast wouldnt prevent you from getting new IOS to the Flash as there should be plenty of space. To my knowledge there shouldnt be any requirements related to Flash other than in the general sense that you shouldnt keep it in a situation where its almost full.
How is your situation on the Flash at the moment? How much free space do you have? Do you have any extra images on the Flash that could be safely removed?
Personally I would try to keep atleast the current IOS on the Flash until you have confirmed everything is ok with the new one.
If you want you could list "show version" and "dir flash:" output here to see your situation.
I have gotten so used to having enough Flash memory on the new models that I have almost forgotten the times with the old PIX models where you had 16MB Flash and you basically had to remove the ASDM image everytime you wanted to upgrade the IOS
Basic way then was to
I have never had to get addiotional Flash memory so far when I have upgraded ASAs.
- Jouni
12-22-2012 09:22 AM
- Jouni
12-25-2012 01:50 PM
Very good, this is what I need to know. Thank you!
