ASA5520 ACL established connections problem
duran_tci
     I have one ASA5520 with version 8.4(3), and a few ACL rules defined. One ACL is permit traffic from one interface(EXT_SERVICE) to another interface(DMZ_SERVICE), if i change that rule to deny traffic, all new connections that match the rule is denied, but no the established connectios. ¿Why the established connections can pass the deny rule? ¿How I can change that? I need create a ACL with deny type and stop all comunications that is running and match the deny rule.
Thanks for help!!
Running-config of my ASA5520:
ciscoasa# show run
: Saved
ASA Version 8.4(3)
hostname ciscoasa
enable password 8ay2wjIyt7RRXU24 encrypted passwd 2wFQnbNIdI.2KYtU encrypted names !
interface GigabitEthernet0/0
description TRUNK 0A 1/2
channel-group 1 mode active
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
description TRUNK 0A 2/2
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
description TRUNK 1A 1/2
no nameif
no security-level
no ip address
no nameif
no security-level
no ip address
channel-group 2 mode active
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
description TRUNK 1A 2/2
no nameif
no security-level
no ip address
interface Management0/0
nameif management-ha
security-level 100
ip address 192.168.199.223 255.255.255.0 !
interface Port-channel1
nameif TRUNK_0A
security-level 0
no ip address
interface Port-channel1.21
vlan 21
nameif DMZ_EXPLO
security-level 70
ip address 192.168.21.223 255.255.255.0 !
interface Port-channel1.31
vlan 31
nameif EXT_EXPLO
security-level 0
ip address 192.168.3.223 255.255.255.0 !
interface Port-channel2
nameif TRUNK_1A
security-level 0
no ip address
interface Port-channel2.11
vlan 11
nameif INTERNA
security-level 90
ip address 192.168.11.223 255.255.255.0 !
interface Port-channel2.22
vlan 22
nameif DMZ_SERVICE
security-level 70
ip address 192.168.22.223 255.255.255.0 !
interface Port-channel2.32
vlan 32
nameif EXT_SERVICE
security-level 0
ip address 192.168.1.151 255.255.255.0 !
boot system disk0:/asa843-k8.bin
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00 object network GW-SERVICE  host 192.168.1.200  description Xircom access-list DMZ_SERVICE_access_out extended permit ip any any inactive access-list DMZ_SERVICE_access_out extended deny ip any any access-list DMZ_SERVICE_access_in extended permit ip any any inactive access-list DMZ_SERVICE_access_in extended deny ip any any access-list EXT_SERVICE_access_in extended permit ip any any inactive access-list EXT_SERVICE_access_in extended deny ip any any access-list EXT_SERVICE_access_out extended permit ip any any inactive access-list EXT_SERVICE_access_out extended deny ip any any access-list global_mpc extended permit ip any any access-list default standard deny any pager lines 24 logging enable logging asdm informational mtu management-ha 1500 mtu TRUNK_0A 1500 mtu DMZ_EXPLO 1500 mtu EXT_EXPLO 1500 mtu TRUNK_1A 1500 mtu INTERNA 1500 mtu DMZ_SERVICE 1500 mtu EXT_SERVICE 1500 no failover icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-647.bin no asdm history enable arp timeout 14400 access-group DMZ_SERVICE_access_in in interface DMZ_SERVICE access-group DMZ_SERVICE_access_out out interface DMZ_SERVICE access-group EXT_SERVICE_access_in in interface EXT_SERVICE access-group EXT_SERVICE_access_out out interface EXT_SERVICE route EXT_SERVICE 0.0.0.0 0.0.0.0 192.168.1.200 1 timeout xlate 3:00:00 timeout pat-xlate 0:00:30 timeout conn 0:05:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00 timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute timeout tcp-proxy-reassembly 0:01:00 timeout floating-conn 0:00:00 dynamic-access-policy-record DfltAccessPolicy user-identity default-domain LOCAL http server enable http 192.168.1.0 255.255.255.0 EXT_SERVICE no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart telnet timeout 5 ssh timeout 5 console timeout 0 threat-detection basic-threat threat-detection statistics access-list no threat-detection statistics tcp-intercept ntp server 84.88.69.32 source EXT_SERVICE prefer ntp server 130.206.3.166 source EXT_SERVICE prefer ntp server 93.92.239.129 source EXT_SERVICE ntp server 212.36.75.245 source EXT_SERVICE
webvpn
class-map global-class
match access-list global_mpc
match default-inspection-traffic
policy-map type inspect dns preset_dns_map  parameters
  message-length maximum client auto
  message-length maximum 512
policy-map type inspect im im
parameters
match protocol msn-im yahoo-im
  drop-connection log
policy-map type inspect ipv6 ipv6
parameters
match header routing-type range 0 255
policy-map global-policy
class global-class
  inspect ctiqbe
  inspect dcerpc
  inspect dns
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect http
  inspect icmp
  inspect icmp error
  inspect ils
  inspect ip-options
  inspect ipsec-pass-thru
  inspect mgcp
  inspect netbios
  inspect pptp
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect snmp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect waas
  inspect xdmcp
class class-default
  inspect ftp
service-policy global-policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:23a90a41872bc184caa246b8848b4183
: end
ciscoasa#
9 Replies 9
Julio Carvajal
Hello Andres,
As you know the ASA is a stateful firewall that does deep packet inspection (DPI) the thing here is that from a higher security level to a lower security level all traffic is permitted no matter what, so you already denied traffic from
EXT_SERVICE to DMZ_SERVICE but all traffic innitiated from DMZ as its a higher security level interface will be allowed, then the Response from the EXT_SERVICE host will be check by the ASA on its connection and xlate table and the packet will match a connection there so it will bypass the ACL (STATEFUL inspection).
Let me know if this makes it clear.
Julio
Please rate helpful posts!
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Thanks for this response now I can see the real problem. But ¿how I can correct this? I need a method to block the established connections with an ACL rule.
If I put EXT_SERVICE and DMZ_SERVICE with the 'security-level 0' and 'same-security-traffic permit inter-interface', perhaps the ACL rule works too for the established connections? Or this issue has not a simple correction?
Thanks for your help Julio!
Best Regards
Pavel Pokorny
If I undrestand well, you want to be sure (after ACL implementation), that no present connection will flow.
Then there 2 ways to do it (as far as I know)l. Clear XLATE, or clear conn address (with parametr :
Enter an IP address or a range of IP addresses: [-]).
Pavel
Thanks for this response Pavel! Affirmative, 'clear conn address' block the connection, but I need other automatic mechanism of block the established connections that match the deny rule, when I put the deny rule in the ACL list.
Not at all Andres,
So, you have to use another way of working.
First disable everything and then allow service by service (between addresses) as needed.
This is the way, you will never have problem, you mentioned.
Because editing of ACL doesn't affect already established connections.
Pavel
Ok Pavel,
     I am try to do that you said, but it doesn't work as I spected, sorry for my error and please if you know a document to explain me how do that better than I was do please let me it and I will try
I have these rules:
access-list DMZ_SERVICE_access_out extended permit tcp any any eq ssh
access-list DMZ_SERVICE_access_in extended permit tcp any any eq ssh
access-list EXT_SERVICE_access_in extended permit tcp any any eq ssh
access-list EXT_SERVICE_access_out extended permit tcp any any eq ssh
Ok, Now I'm simulating a hacker that connect over ssh to one host in DMZ_SERVICE network, connect to that host over ssh, and while the ssh connection is running I write this to the ASA:
access-list EXT_SERVICE_access_in line 1 extended permit tcp any any eq ssh  inactive
access-list DMZ_SERVICE_access_in line 1 extended permit tcp any any eq ssh  inactive
access-list DMZ_SERVICE_access_out line 1 extended permit tcp any any eq ssh  inactive
access-list EXT_SERVICE_access_out line 1 extended permit tcp any any eq ssh  inactive
The ssh connection is still alive
Sorry if I wasn't understand your advice. Please coud you explain me the method of cut the stablished malicious established connections?
I see that if I define a 'Service Police Rule' the ping(icmp traffic) is blocked with the ACL change to deny.
      class-map global-class1
        class global-class1
          inspect icmp
¿Perhaps is the this the way?
Hi Andres,
Through CLI of ASA, or ASDM where you put command clear connection ............
This is the only way I know.
About the ping (IMHO) it's another situation, because for each echo-request is echo-reply (as pair). For ping 1 is pair 1 and "established connection" 1. For another just change numbers. If you change to deny pings are then denied. It doesn't work with "normal" connection as ssh.
Pavel
Hello Pavel,
     I use CLI for the command clear conn ... and I use ASDM for input ACL rules (ASDM only for usability). I have two monitors one with the ASDM and other with the CLI over serial RS232 cable.
For the ping question you are in true, is another situation. ¿Any idea or help for this situation?
Really thanks for your help!
Regards!
Hello Andres,
The thing is that as soon as the ASA knows a valid connection is established the only way to drop it as Pavel said would be with a clear connection for that particular session.
As an example you can kill a ssh session with the command Kill xxx (Session id) into the ASA.
What you can configure is a Iddle timeout,maximum amount of connections to a host,etc.
But as soon as the connection is valid by the ASA you cannot terminated it by using an ACL.
Julio
Please rate post that helps you
Julio Carvajal
