08-22-2019 08:41 PM
Good evening,
I am a newbie and I am asking if someone can help me with two problems? I am having a headache trying to connect with the VPN client using the Outside interface and I am trying to access an internal host from the outside over AnyConnect VPN to authenticate using RADIUS.
#1. I have an ASAv in AWS configured with Cisco AnyConnect client. When i use the VPN client to connect to the outside public IP, the client just spins and the ASDM log-viewer shows "Deny tcp src Outside <My IP address> dst management by access-group Outside access in".
I have configured the webvpn for 'enable Outside' but no luck..Can someone please tell me why this is denied and why it cannot connect via the Outside interface?
#2. I want to authenticate to the internal RADIUS server (10.0.4.132) which I cannot ping... but I can ping the inside interface address which is 10.0.4.194. The route table shows everything as local or connected except for the static route of 0.0.0.0 0.0.0.0 via 10.0.2.1(management), which is the GOLR to network 0.0.0.0.
I have posted my config below, can someone tell me what I have misconfigured and what I need to configure to get this to work?
Thanks.
name 173.37.145.8 tools.cisco.com
no mac-address auto
ip local pool VPN-POOL 192.168.20.2-192.168.20.252 mask 255.255.255.0
interface GigabitEthernet0/0
description AWS Eth1 Outside interface
nameif Outside
security-level 0
ip address 15.200.21.205 255.255.255.240
interface GigabitEthernet0/1
description AWS Eth2 Inside interface
nameif Inside
security-level 100
ip address 10.0.4.194 255.255.255.240
interface Management0/0
description AWS Eth0
nameif management
security-level 100
ip address dhcp setroute
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network VPN
subnet 192.168.20.0 255.255.255.0
object network AWS_Inside
subnet 10.0.4.0 255.255.255.0
object network RAD-YUB2
host 10.0.4.132
access-list AnyConnect_Client_Local_Print extended deny ip any4 any4
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq lpd
access-list AnyConnect_Client_Local_Print remark IPP: Internet Printing Protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 631
access-list AnyConnect_Client_Local_Print remark Windows' printing port
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 9100
access-list AnyConnect_Client_Local_Print remark mDNS: multicast DNS protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.251 eq 5353
access-list AnyConnect_Client_Local_Print remark LLMNR: Link Local Multicast Name Resolution protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.252 eq 5355
access-list AnyConnect_Client_Local_Print remark TCP/NetBIOS protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 137
access-list AnyConnect_Client_Local_Print extended permit udp any4 any4 eq netbios-ns
access-list spit-tunnel standard permit 10.0.4.0 255.255.255.0
access-list vpn-acl extended permit tcp any any
access-list vpn-acl extended permit ip 10.0.4.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list RAD-YUB2 standard permit any4
access-list Outside_access_in remark Auth server and Yubi MFA
access-list Outside_access_in extended permit ip any object RAD-YUB2
pager lines 23
mtu Outside 1500
mtu Inside 1500
mtu management 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 8192
nat (Inside,Outside) source static AWS_Inside AWS_Inside destination static VPN VPN no-proxy-arp
nat (Inside,Outside) static RAD-YUB2
access-group Outside_access_in in interface Outside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
aaa-server RADIUS protocol radius
aaa-server RADIUS (Inside) host 10.0.4.132
timeout 5
key *****
authentication-port 1812
accounting-port 1813
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication login-history
http server enable
http 0.0.0.0 0.0.0.0 management
no snmp-server location
no snmp-server contact
## Crypto omitted for space
telnet timeout 5
ssh stricthostkeycheck
ssh <My IP> 255.255.255.255 management
ssh 0.0.0.0 0.0.0.0 management
ssh timeout 30
ssh version 1 2
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point self-signed Outside
ssl trust-point self-signed Inside
ssl trust-point self-signed management
webvpn
enable Outside
hsts
enable
max-age 31536000
include-sub-domains
no preload
anyconnect image disk0:/anyconnect-win-4.3.05017-k9.pkg 1
anyconnect image disk0:/anyconnect-macos-4.6.03049-webdeploy-k9.pkg 2
anyconnect enable
tunnel-group-list enable
cache
disable
error-recovery disable
group-policy GroupPolicy_VPN_users internal
group-policy GroupPolicy_VPN_users attributes
wins-server none
dns-server value 10.0.3.5
vpn-tunnel-protocol ssl-client ssl-clientless
split-tunnel-policy tunnelspecified
split-tunnel-network-list value vpn-acl
default-domain value x.com
dynamic-access-policy-record DfltAccessPolicy
username x password x privilege 15
username y password y privilege 15
username x attributes
service-type admin
tunnel-group VPN_users type remote-access
tunnel-group VPN_users general-attributes
address-pool VPN-POOL
authentication-server-group RADIUS
default-group-policy GroupPolicy_VPN_users
tunnel-group VPN_users webvpn-attributes
group-alias VPN_users enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect ip-options
inspect netbios
inspect rtsp
inspect sunrpc
inspect tftp
inspect xdmcp
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect esmtp
inspect sqlnet
inspect sip
inspect skinny
policy-map type inspect dns migrated_dns_map_2
parameters
no tcp-inspection
policy-map type inspect dns migrated_dns_map_1
parameters
no tcp-inspection
service-policy global_policy global
prompt hostname
call-home reporting anonymous
call-home
profile CiscoTAC-1
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
profile License
: end
M-ASAv2
08-23-2019 08:23 AM
08-24-2019 02:40 PM
That's interesting, you can ping inside interface on firewall but not the inside host. Can you cross verify the host is tagged to inside network subnet.
And "10.0.3.5" is the IP belongs to Management network ?
