I configured the zone based firewall and the rules seem to work fine. However, the speeds are really bad. Even when just using pass actions it only reaches 1.5 Gbit/s (with the firewall turned off it reaches 9-10 Gbit/s).
This even happens with very minimal ZBF config. There is an VM-Host connected to the first 10GE interface, the VMs reach 10 Gbit/s when using iperf without ZBF active, after enabling they slow down.
class-map type inspect match-any cmap--test match protocol tcp match protocol udp ! policy-map type inspect pmap--test class type inspect cmap--test inspect class class-default drop ! zone security test-in zone security test-out zone-pair security in-to-out source test-in destination test-out service-policy type inspect pmap--test ! interface TenGigabitEthernet0/0/0.1 encapsulation dot1Q 1000 ip address 192.168.1.1 255.255.255.192 zone-member security test-in ! interface TenGigabitEthernet0/0/0.2 encapsulation dot1Q 2000 ip address 192.168.0.1 255.255.255.0 zone-member security test-out
Is there any way to improve ZBF performance?
configuration look good. what image you running on this box?
I am running asr1001x-universalk9.16.09.04.SPA.bin.
I have AES, 20GE throughput, and 10GE port licenses activated.
Yes, it is version 16.9.4. I have attached the output of "sh license feature".
@AlexanderVotteler wrote:
firewall no no no no no
What happens if the FW license is enabled?
What is the command to activate this license?
NOTE: Router is running 16.9.X and this equates to Smart Licensing.
Read this: Configuring a Cisco Right-To-Use License
You need to activate the evaluation license for the "firewall" feature
license boot level firewall
and accept the EULA
license accept end user agreement
The command
is not available on my machine. Does Smart licensing imply I won't be able to activate this license unless activating smart licensing? Should I downgrade to 16.6.X allow activating without smart licensing?
Thanks for your help!
I just did some more testing. Using iperf3 a single connection cannot reach more than 1.5 Gbit/s while ZBF is turned on. However, I can start 3 sessions and each of the go above 1 Gbit. It seems single connections are limited, is there a workaround for this issue?
Downgrading doesn't help as well. The command stays unavailable.
I do not think this is a supported command since the configuration guide you mentioned does only say adventerprise, advipservices and ipbase license levels can be activated.
